Did record some stuff with alfa, tho I'm not sure it saved everything
I did accelerate and wait 30s 3 times, and yes EGR gets back to 0 after 30 sec
Then I drove back home, with some speed bumper on the road (dunno how you call this things)
http://www78.zippyshare.com/v/oDv3NANc/file.html
Not sure you'll be able to use it on computer, raw data but you can put it here \Phone\Android\data\com.android.AlfaOBD\files\logs
Also looking at logs, found this
Target EGR position: -0,35 mm
EGR measured position: 0,00 mm
Last learn of DC EGR engine offset: 0,00 mm
So there is an offset possible ? maybe the -0.4 is an impossible value but configured this way to be sure the EGR is totally closed ?
So after cleaning EGR few days later engine light came back with
Error code: P0409
Exhaust Gas Recirculation (EGR) position sensor
Error intermittent
Error code: P2620 (never had this one before, hope I didn't break it when I first removed this part, cleared fault and didn't came back yet)
Motorized throttle (feedback)
No signal
Error intermittent
Error counter: 35
Error code: P010F
Air mass/air flow meter incongruence
Above top limit
Error present
So, the throttle one only came once when I checked, P010F is almost always there, and EGR appears sometime.
Slow mod still happen when lowering gear (5 to 4 I believe, tho I only notice it after I want to speed up, coz it doesn't give any warning or light)
