Old 28-03-2013   #16
Re: Fiat Punto Evo 2011, Aux?
Can you remember what cables were already in the plug when you connected it up?
Do you have a USB input?
I notice that the aux terminals have the USB input cables on them, the other end of the connector (where the blue bit is) there are some AF terminals.
I'm looking at a cable on Amazon thats under 7 for this.
EvoStevo is offline Reply With Quote Quote
Old 28-03-2013   #17
Israel
Hi, I have similar issue so I'm jumping on this discussion.
I own a 2011 Punto Evo (without blue&me) and I'm trying to get aux using this method.
So I've purchased the appropriate cable and plugged in into the aux input behind the head unit but when I tap "Media" twice, with no cd in the drive, I get "No source available" on screen
What am I doing wrong?
I have the Delphi head unit, F199, and I think I've done everything just as described above so I can't find the reason that it's not working.
Took some photos in the process so I hope some other member might spot the error: hxxp://db.tt/2Vd2qqsM (can't post links yet since I'm new. Replace hxxp with http).
idan is offline Reply With Quote Quote
Old 28-03-2013   #18
Frost, you linked to one on Amazon.
is that the cable that works?
Old 29-03-2013   #19
No do not get tht one from amazon it jut doesn't work. I have managed to get it done properly with this it will work 100% I ha e pics on my profile showing you what to do when u get it and how to connect
U need this
http://item.mobileweb.ebay.co.uk/vie...id=93417915774
frost719 is offline Reply With Quote Quote
Old 29-03-2013   #20
Also read this forum it has everything u need to get this working I helped another with this. https://www.fiatforum.com/punto-v/320203-aux-punto-2012-easy.html
Old 29-03-2013   #21
Israel
Quote Originally Posted by frost719 View Post
Hey frost, could you please check what's the HW and SW versions on your head unit? Maybe that's the reason that my head unit can't use the aux in cable.
My HW version is: 28302823 and SW version: 18.
Thanks in advance!
Dislikes Nir Hendin disliked this post
Old 29-03-2013   #22
But that ones about 12 more than the amazon one.
Did you get the amazon one and did it fit in the hole?
Thats all I need as I can then rewire it.
I'm not too keen getting something else from Italy
Old 01-04-2013   #23
India
Dear Friends,
I am new to this Fiatforum i am from India, i own a Fiat Punto 2012 Dynamic which has no BnM and no aux and usb, can u also help me in providing details for aux connection, my car is with Delphi F199 music player.
Regards
Atul
atulkumbhar is offline Reply With Quote Quote
Old 02-04-2013   #24
Frost is the cable you used connecting into the aux inputs or the other end?
I already have a cable that connects into those pins - I wonder if its from the blue & me unit?
Thats on the Yellow connector - the Blue one is at the other end.
Old 03-04-2013   #25
It has to be the blue one from eBay. It's coming from Italy and it 100% works.
Old 05-04-2013   #26
So it's not going into the aux input then as that is the Yellow one.
The blue connector is for the CD changer at the outside edge of the radio.
Old 07-04-2013   #27
Frost, when you want to use the cable what button do you press and how many times?
Old 22-04-2013   #28
The media button push till it comes up AUX or on certain models u push cd and some other models SRC (source) button
Old 27-04-2013   #29
Cheers, my aux input is definitely used by the B&M, all that is left is the CD changer input.
I'm thinking I might want an aux input more than the B&M as I'd like to improve the audio from my Nexu 7 when using it as sat nav.
Old 14-05-2013   #30
Hey guys, I've jus bought a 60 plate evo, came with the dreaded blue and me built in, I want to get the aux lead, can anyone point me in the right direction? And how hard are they to install I'm guessing remove stereo plug it in and go...my stereo is the stock one
Sullievo is offline Reply With Quote Quote
Punto Evo - Where is the Aux input? EvoStevo I.C.E 4 06-03-2012 22:03
adapter (usb,aux ++) for fiat evo 2010 with oem radio gruyon Blue and Me 0 22-01-2012 18:07
adapter (usb,aux ++) for fiat evo 2010 with oem radio gruyon I.C.E 0 22-01-2012 18:06
