C Cdw New member Joined Mar 30, 2019 Messages 4 Points 2 Mar 31, 2019 #1 Where can I find the fuel pump relay? Van won’t start, no clicking sound from a relay or ticking from the pump. It’s a 1.6 diesel, 2007 plate. TIA
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,989 Points 7,837 Location Near the M4 Mar 31, 2019 #2 You mean the lift pump.. in the fuel tank. It only runs to build pressure.. if its to pressure it doesnt need to run. I would het the filter housinh off bulkhead.. and check the fuel there.. Charlie
OP OP C Cdw New member Joined Mar 30, 2019 Messages 4 Points 2 Mar 31, 2019 #3 Will try that. Thanks.
g8rpi Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Joined Nov 11, 2013 Messages 4,599 Points 1,167 Location Cambridge Mar 31, 2019 #4 Cdw said: Where can I find the fuel pump relay? Van won’t start, no clicking sound from a relay or ticking from the pump. It’s a 1.6 diesel, 2007 plate. TIA Click to expand... Check the inertia switch in the footwell. press the rubber top down to see if it clicks back on. See your handbook (or google it) for more details. Robert G8RPI. Last edited: Mar 31, 2019
OP OP C Cdw New member Joined Mar 30, 2019 Messages 4 Points 2 Apr 1, 2019 #5 I cannot find this switch. Looked all over. Any mor3 help please?
g8rpi Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Joined Nov 11, 2013 Messages 4,599 Points 1,167 Location Cambridge Apr 2, 2019 #6 Cdw said: I cannot find this switch. Looked all over. Any mor3 help please? Click to expand... Well owners mnual is first place to look, but if you don't have that then try https://www.fiatforum.com/scudo/241376-scudo-fuel-cut-off.html (this 07 has it in the engine compartment) http://www.fiatia.com/fman-537.html
