Hi. I have recently taken my ducato to a diesel mechanic to try and source the problem with the over fuelling smell coming from the exhaust.
He had an idea that the fuel pump could be out of timing? So he's checked the timing and everything is spot on. He found a split fuel hose that he change. The engine is a mechanical turbo diesel so very basic with no egr valves etc.. So I've been told.
He advised maybe the next thing to do would be to send the pump off to be checked /reconditioned if required.
Wanted to get some more input from anybody that is used to this type of engine? It's had full engine service. Injectors have been re-tipped and tested. All hoses have been checked. Now timing and fuel pump timing is all correct.. What's next!!
