Morning All,
Just noticed some more activity on this subject so thought I would report complete success using the FiatECUScan product. I was able to update the two parameters to say that the oil had been changed and that a service had been carried out.
I would have liked to have tried the other products as well but as I had a laptop available and the FiatECUScan software provided additional functionality that's what I went for.
In terms of cost (assuming the laptop already available) I spent just under £150. The FiatECUScan s/w was about £45 and the cable I went for was £93.50 (
http://www.obdkey.com/obd_usb_info.asp? ). There are cheaper interface solutions available but I did a bit of reading and fancied this one.
For a little more detail, once connected I ran a scan and it produced the following report :
Scanning ...
Engine
Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4)
ISO Code: FD 86 CB 85 A8
Body
Marelli Body Computer MY03
ISO Code: 40 83 91 02 AB
Dashboard
Service Interval Reset (Comfort)
ISO Code: 32 83 10 02 1C
COMPLETED
My car is a 120HP 8v MultiJet Doblo and although this is not mentioned in the software compatibility list the 1.9 JTD also appears to have the same components installed so appears to be compatible.
There is a lot that this software can display and I guess the art is in knowing how to interpret it and what to look for in the event of a problem but here is a listing of the parameters on my 2009 120HP MultiJet for interest.
F2 Info
ECU ISO code FD 86 CB 85 A8
FIAT drawing number 51809513
Hardware number 0281013675
Hardware version 00
Software number 1037388119
Software version 3442
Homologation number 22344
ECU programming date 05/30/2009
ECU ISO code 32 83 10 02 1C
ECU programming date 07/03/2009
10/06/2011 19:01:49
A/C pressure sensor: mBar
A/C request:
Accelerator pedal track: Acc. Pot. Track 1
Air temperature (Boost/Manifold): 72.36 °C
Air temperature (MAF): 38.26 °C
Air temperature signal (Boost/Manifold): 1,280.3 mV
Average distance last 5 regenerations: 426 mi
Average temperature of last 5 regenerations: 633.66 °C
Baro pressure: 1,005 mBar
Battery voltage: 12.610 V
Boost control/solenoid: 74.96 %
Boost pressure signal: 1,617.5 mV
Boost pressure: 1,002 mBar
Brake light switch: OFF
Brake pedal switch: Released
Clutch pedal switch: Pressed
Cruise control request:
Cruise control switch:
Desired boost pressure: 980 mBar
Desired fuel pressure: 270.00 bar
Desired intake air quantity: 3,275.5 mg/i
Differential pressure sensor: 0 mBar
Distance to next Oil change: 31,069 mi
Distance to next Oil change: 6,835 mi
ECU ISO Code: FD 86 CB 85 A8
ECU programming date: 05/30/2009
EGR control: OFF
EGR valve opening: 4.00 %
Engine ECU: Programmed
Engine oil level: %
Engine oil pressure: Not significant
Engine speed: 0 rpm
Engine start permission: Allowed
Engine temperature light:
Engine temperature light: OFF
Engine temperature: 81.26 °C
EXECUTING ADJUSTMENT...
Failure indicator light:
Failure indicator light: Flashing
Fuel gauge: 23.023 %
Fuel pressure (Gauge): 4.30 bar
Fuel pressure sensor: 503.3 mV
Fuel pump relay: OFF
Fuel temperature signal: 2,726.9 mV
Fuel temperature: 33.66 °C
Gas pedal position signal 1: 777.0 mV
Gas pedal position signal 2: 395.8 mV
Gas pedal position: 0.00 %
Gear engaged: None/Neutral
Gearbox type: Not learnt
Glow plug circuit: OFF
Glow plugs indicator light: OFF
Hardware number: 0281013675
Hardware version: 00
Homologation number: 22344
Inj. correction Cyl. 1: 0.00 mm³/i
Inj. correction Cyl. 2: 0.00 mm³/i
Inj. correction Cyl. 3: 0.00 mm³/i
Inj. correction Cyl. 4: 0.00 mm³/i
Inj. correction Cyl. 5: mm³/i
Injector code Cyl. 1: 8SR5B2AAA
Injector code Cyl. 2: A1S1HBCAA
Injector code Cyl. 3: AIAR765AA
Injector code Cyl. 4: AIAAC2EAA
Injector code Cyl. 5:
Inlet circ. solenoid valve opening: %
Intake air quantity signal period: 0.553 ms
Intake air quantity: 0.0 mg/i
Lambda oxygen concentration: %
Lambda sensor signal: V
Last 5 regenerations average duration: 599 sec
Max. engine speed time: 0.00 sec
Maximum engine speed: 0 rpm
Number of programmings: 0
Odometer at last DPF replacement: 15,671 mi
Odometer at last Oil change: 15,672.2 mi
Odometer at last programming: 0.0 mi
Odometer at last regeneration: 29.0 mi
Odometer: 15,687.9 mi
Oil change (only for version with DPF)
Oil change counter: 1
Oil degradation level: 100.00 %
Overrev count: 0
Particle filter status: Not clogged
Particle filter temperature: 120.36 °C
Particulate filter clogging: 17.06 %
Pre-catalyser temperature: 37.46 °C
Pressure regulator opening (DRV): %
Pressure regulator opening (MPROP): 0.00 %
Regeneration progress: 0.000 %
Software number: 1037388119
Software version: 3442
Throttle angle: 5.00 %
Total fuel quantity: 0.000 mm³/i
Universal code: Disabled
Vehicle speed: 0.0 mph
Vehicle version: with DPF
Water in fuel warning light: OFF
Hope this helps and all the best.
Peter
