View Poll Results: What are you using now | |||
Forum Tradition/Default | ![]() ![]() ![]() ![]() | 8 | 28.57% |
Forum Traditional (Full Screen) | ![]() ![]() ![]() ![]() | 20 | 71.43% |
Voters: 28. You may not vote on this poll |
![]() | #1 |
![]() | Full Screen Forum I am thinking about the ideal size for my next sig and I just wanted to know what size the majority of people used for the forum display. I have just switched to full screen mode, thanks to Sammi pointing it out and my sig along with everyone elses is actually not wide enough for optimum veiwing pleasure. To find out what your using, go to your user CP and click on Edit options, then go down to Miscellaneous Options and under "forum skin" there will be three options to choose.. I can't see the difference between Forum Default and Forum Traditional, but if you click on Fiat Forum Traditional(full screen) it does exactly what it says on the tin.
__________________ ![]() |
![]() | #2 |
![]() | Re: Full Screen Forum I use full screen, would be an idiot not to ![]()
__________________ 3rd Fiat - luck as good as ever |
![]() | #3 | ||
***** Friendly | Re: Full Screen Forum i use Full screen, after getting my new laptop ![]() my old monitor was so small, it didnt make any diffence what you used ![]()
![]() | #4 | ||
Posts: 344 Thanks: 0 Trader Rating: 0 ![]() | Re: Full Screen Forum Hey, didnt even know that there was a different one! ![]() But im using full screen now!!! ![]() Thanks. Theresa
![]() | #5 |
![]() | Re: Full Screen Forum ![]() Hey, didnt even know that there was a different one! ![]() But im using full screen now!!! ![]() Thanks. Theresa ![]() ![]()
![]() | #6 |
![]() | Re: Full Screen Forum Always used fullscreen for aslong as I can remember, on glorious WXGA+ widescreen ![]() But, some people may still use 800*600 screens I am guessing?
__________________ Now drives: BMW 635d (wow!) Past: Renault Laguna Coupe GT 180. Laguna Initiale dci. 52 Megane 1.9dCi, Y-reg Fiat Brava JTD (Pale Blue) (2006), '51 Fiat Brava 80 SX (black) (2006), M-reg UNO (2003-2004) |
![]() | #7 |
![]() | Re: Full Screen Forum So I am presuming that the higher the resolution your using the smaller the sigs are going to be in comparison to the forum ? Any chance of a screenshot or two peeps ?
![]() | #8 | ||
***** Friendly | Re: Full Screen Forum well this is 1400*1050 (do you mean the laptop paul ![]() ![]() and the other is 800*600 both in full screen
![]() | #9 |
![]() | Re: Full Screen Forum Basically the resolution shows how much you can show on your screen, rather than the screen size. A huge resolution on a small screen means everything will be nice and sharp but very small, so difficult to read, but you can fit a lot more on. A low resolution on a large screen means you can't fit a great deal on but obviously everything is larger. For instance Koa your plasma screen, it is very large but has a fairly low resolution, without checking back, I will guess it's (for example) about 1200x800 if it is widescreen and (for example) 36". My laptop screen has a similar resolution but it's 15.4" widescreen, I actually can see as much as you on my screen but of course it's smaller and sharper, so i'd have to sit closer than you. Higher the resolution, the higher the amount of info on the screen. Example of mine is below. Anybody will notice it won't fit on their screen if they use a lower resolution than me, even if they had a 100ft screen. My old laptop (serin's) has a SVGA+ screen of 1400*1050 (not widescreen like I think he has said) - that means he can fit easily 2 or even 4 websites on the screen at the same time.
![]() | #10 | ||
| Re: Full Screen Forum i tend to use traditional after i got my new screen, as using 1600x1020 resolution and full screen, its a bit wide ![]() And mark (and anyone else who dont know), you can change between traditional and full screen using the drop down box at the bottom of each page...
![]() | #11 |
![]() | Re: Full Screen Forum Serin, yours is 1400*1050 SVGA+ not widescreen (I mean the TFT, not the FF window!) my new one is 1280*800 WXGA+ widescreen. You can fit more on the screen than I can.
![]() | #12 | ||
| Re: Full Screen Forum ![]() Anybody will notice it won't fit on their screen if they use a lower resolution than me, even if they had a 100ft screen. My old laptop (serin's) has a SVGA+ screen of 1400*1050 (not widescreen like I think he has said) - that means he can fit easily 2 or even 4 websites on the screen at the same time.
![]() | #13 |
![]() | Re: Full Screen Forum Your screen cost as much as my laptop ![]()
![]() | #14 | ||
| Re: Full Screen Forum just found i can use a resolution of 2048x1536, thats just silly size ![]() It scrolls around the screen (wont all fit on at once)
![]() | #15 | ||
Posts: 147 Thanks: 0 Trader Rating: 0 ![]() | Re: Full Screen Forum I use full screen mode but still created my sig so it fits the traditional width. I don't know about anyone else, but I don't actually use my browser maximised, I have it minimised to about the same size as 800x600 - I do this because my LCD is a 20" widescreen running in 1680x1050! ![]() Similarly, I don't centre my sig either because it looks completely lost in the middle when you run your browser maximised - especially at a high screen res! Ooh... the dilemma! ![]()
Full Restoration Thread | Dunc Uno Turbo | Lets Talk FIAT | 175 | 04-10-2005 19:50 |
What is with this forum?? | Steven | Leisure Lounge | 66 | 12-01-2004 02:45 |
![]() | Lex | Punto (Mk2/2b) | 6 | 22-09-2003 21:36 |
Forum Speed - Ideas | ben | Polling Station | 15 | 14-02-2003 20:14 |
New poll forum up... | ben | Latest News | 0 | 18-11-2002 05:10 |
