Eurocar parts are listing both ABS and Non ABS versions and as the car is 100 miles away I am hoping to get the right part!!
If it's a 2013 car, it will definitely have ABS.
If in doubt, buy both and return the one you don't use.
I am fairly sure the answer is the same but it is a 2010
My 2010 1.1 Eco active has ABS (well it has the sensors on the front hubs anyway!)
The diameter of the drum is stamped onto the drums edge. I think for the diesel there all 180mm
Although everyone I have seen has been bosch.
I don't know if the wheel cylinders are interchangeable. I am fairly sure the shoes aren't, different fixings.
I have taken a gamble on bosch before now and not been bitten yet. Maybe Fiat dropped ap lockead and only fitted them on none ABS early cars
Some catalogues only mention Bosch for ABS drums others mention ap lockheed. There's loads of mistakes online. Who knows. But 99% it will turn out to be bosch
well thats for a pre 2012. There a different section for post 2012 cars
If this is a 169 Panda, I'm sure the ABS cars are all Bosch, and the Lockheed was only on non-ABS. As said above, at 2010, this will be an ABS car.
