Hello
I want to retrofit fog lights on a 2008 Panda 1.2 Dynamic. After some research using elearn I found out that all required pins are present on bcm (pin for relay activation and for fog light switch signal). Fog light indicator is also available on instrument panel. Of course the wiring is not present but can be added on harnesses.
However when I tried to enable the feature via proxi alignment in mes I got the message "configuration not supported by system error".
I can't understand this. "Dynamic" is quite of a mainstream trim level with most Pandas having fog lights. So it seems quite difficult to place a different bcm.
Is there any chance my ELM327 lead not being able to get the feature enabled?
P.S.: I know that I can simply do the job with a relay and a universal on-off switch but I want to avoid this option.
