![]() | #31 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Much like the car I wanted to bring this thread out of hibernation. Car stays on the drive over winter and the engine gets a 5 to 10 min run every week to keep charge in the battery. Time to get it back on the road now. Things seem to have progressed but not necessarily in a good way. Within that 10 min engine run I now readily have smoke. Hoping to attach a video showing the location. With the air box off it clearly comes from beneath the exhaust manifold cover. Any ideas on such easily produced smoke in that area? Many thanks. *Don't seem to be able to upload video so attached photo instead.
![]() | #32 | ||
Posts: 2,816 Thanks: 236 Trader Rating: 0 ![]() | Re: Panda 100hp oil smell instead of guessing take the shield off and visibly check its not a normal place for oil to leak on these engines
![]() | #33 |
Posts: 1,874 Thanks: 119 Trader Rating: 0 ![]() | Re: Panda 100hp oil smell Isn't that where the oilfilter lives? gr J
__________________ "Look for the ridiculous in everything and you will find it". - Jules Renard |
![]() | #34 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | Re: Panda 100hp oil smell My Panda 100hp had the same problem, smell of burnt oil in the interior. To cut a long story short, it turned out to bee a very slight leak from the oil filler cap. I bought a brand new cap from Fiat, which would not fit right. So I only changed the rubber seal, problem fixed. Have you checked the filler cap yet, I surely hope you have the same problem... with an easy fix ![]()
![]() | #35 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | Re: Panda 100hp oil smell I forgot to write that the slightly leaking oil found its way to the exhaust manifold where it burnt with that typical smell as a result. I did not see the cause, but my friendly garage pointed it out to mee after 1 minute.
![]() | #36 | ||
Posts: 16,775 Thanks: 843 Trader Rating: 0 ![]() | Re: Panda 100hp oil smell Mine had an oil smell when the gear shift seal failed. It's at the top of the gearbox where the shifter shaft goes in. The fix is quick. You will need a new seal and roll pin. Talk to Shop 4 Parts. Take out the battery, Set gears to neutral. Disconnect gear shift cables. Remove top of gearbox. Knock out the roll pin take it apart fit seal reassemble and put it all back together. Mine hardly touched the gearbox oil level but the leak smelled of hot oil after a short drive. I used Loctite 518 gasket replacement but you could also use RTV. There is no paper gasket.
![]() | tyu067 | Punto Evo | 4 | 04-06-2020 23:19 |
![]() | HannsG | Panda | 3 | 24-06-2018 01:59 |
![]() | emjharts | Panda | 1 | 10-01-2010 03:21 |
