- Jun 3, 2016
- 149
- 56
just a question,
When i bought my 05 plate panda from 'dodgy john!' all was well (ish) then after a few months i noticed a few blemishes on the wheel arch so took a look to find road dirt had acuminated up the wheel arch next to the fuel filler. I removed almost a bucket of it! Thinking that was the problem all was well but 4 years later the rust around the filler cap is pretty bad on all the screws that hold the fuel pipe to the body BUt further down the wheel arch had really gone rusty, then i noticed the sill just after the wheel arch had some rust stains which on closer inspection turned out to be the start of a 4 inch hole in the sill hidden by the plastic rubbery paint used to protect them.
Just wondered if this is a known problem with the panda or did i get the 'Friday afternoon special'?
The rest of the care body is mint. On the plus side the hole in the sill is in a good spot for welding so not overly worried.
The car did spend an afternoon that November up to its sills in flood water but there is a drain hole just next to the hole so either that was blocked or ive just been unlucky!
