There have been a few threads on sticking door handles, but I think I have a different problem.
For a long time, I have found that the passenger front door sticks shut if it isn't used for a while. The handle works fine, but the door seal seems to be sticking to the frame. It needs someone inside to give it a good shove to open the door.
The car has been spending more time than usual sitting on the drive recently, and the same thing happened today with the driver's door. I had to climb in the back and push the door open from inside. Oddly, the back doors never stick.
Is there something I should use to clean around the doors to stop this - something that won't rot the rubber door seals?
