Thread Tools
Old 1 Week Ago   #1
Normal oil usage
So I was checking out the underbonnet this morning, after having driven through some flood waters yesterday. (hope all the Yorkshire folk are ok), and noticed the oil was just touching the dip stick. now I got the car in early November when the oil was only showing halfway up the dipstick. I monitored it then and I couldn't see any oil leaks, and still can't. I haven't done many miles in that time (< 2000 miles) so that seems like a lot?
Oil doesn't seem to have coolant in, and coolant doesn't seem to have oil in. and I haven't had any behaviour to suggest a head gasket issue. so is that normal oil usage? my prior 2 cars never needed oil between annual services at all.
benj111 is offline Reply With Quote Quote
Old 1 Week Ago   #2
varesecrazy has donated!
Re: Normal oil usage
Hi.
Petrol. Diesel or twinair..
They are all different
How many miles on this car?
varesecrazy is online now Reply With Quote Quote
Old 1 Week Ago   #3
Sorry, 1.2, 100K miles, petrol... well thats what I've been putting in it.
Old 1 Week Ago   #4
Moderator
My 1.2 with 95k does not require topping up between oil changes every 10,000 miles. Uses perhaps 100ml every 5k.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 1 Week Ago   #5
Thats well within 'acceptable limits' for NEW cars.
At 100k it could well be 'burning' some
But do check for things like a rusty sump pan..
Charlie
Old 1 Week Ago   #6
Quote Originally Posted by jrkitching
Thanks, manual says "Max engine oil consumption is usually 400 grams every 1000 km." which i was guessing is heavily erring on the side of caution.
Quote Originally Posted by varesecrazy View Post
Well it isn't leaving any presents on the drive, so I'm not worried about the sump. I'm guessing you're right about it burning some.
Old 1 Week Ago   #7
Quote Originally Posted by benj111 View Post
It is probably burning it, normally the valve stem seals get hard and don't seal the oil so well and allow the oil to run down the stem in to the cylinders and burn it, stem seals are cheap, not sure how quick the job is to do on a panda.
Jockcl500 is offline Reply With Quote Quote
Old 1 Week Ago   #8
The previous owner might have put a thin oil in last time.
I've got a 53 reg Panda 1.2 with 152k. I always use 10/40 semi and top up about 200ml every 3k.
Make sure the thermostat is working spot on. If you are running cool it will burn oil.
GeorgeDamper is offline Reply With Quote Quote
Old 1 Week Ago   #9
Quote Originally Posted by Jockcl500
I'll have a look into that, more fruitful than looking into PCV valves (hint, the Panda doesn't seem to have them)
Quote Originally Posted by GeorgeDamper View Post
Thermostat was brand new in November, anyway the temperature gauge always rises nicely to the middle and stays there. the oil that came with it was 5w40 so thats only thinner when cold(?) so shouldn't be the problem?
Old 1 Week Ago   #10
I have a tool for doing Ford cvh engines in place, did my brothers xr3i ones in 20 minutes while visiting him in France
I'm not sure how much work is involved in changing the Panda ones
The viscosity of the oil won't make any difference, if the seals are shot they need replacing.
I would try running a Forte flush and seal conditioner through, it could make the seals supple enough to reseal them, it may just work.
Old 1 Week Ago   #11
Quote Originally Posted by Jockcl500 View Post
Thanks I'll have a look at the Forte stuff.
Valve stem replacement look quite involved, not sure if i'm feeling that brave, maybe when the weather improves, but I can guarantee it will take me longer than 20 minutes.
Old 1 Week Ago   #12
yep sounds about right.
mine has always used a bit more in winter than summer. Never bothered to find out why.
I use 10/40
5/40 is like water when cold. I wouldn't be surprised if there isn't a bit of blue smoke on start up if the car stood for a few days.
just keep it topped up to the top. A Good portion of the engine cooling is via the oil. Even at half way its a pint or more below capacity.
Fingers cross to will be gold for at least another 100K
Likes GeorgeDamper liked this post
koalar is offline Reply With Quote Quote
Old 1 Week Ago   #13
There's a few "how to" vids on here
https://www.youtube.com/results?sear...lve+stem+seals
DaveMcT is offline Reply With Quote Quote
Old 1 Week Ago   #14
Ok thanks all, I've ordered some of the Forte Seal Conditioner, so I'll do that first off and feed back here (or more likely forget).
Old 1 Week Ago   #15
Netherlands
If it has been used on short drives (not heated properly) condensation might have added fluid getting the level at max. One proper run heating the oil up to normal working temperature will loose all that water leaving you with a low level.
I'd check it regularly in the coming time. Might be nothing at all.
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Thread Tools
(T) 1.6 oil usage siadz Stilo 7 14-08-2017 13:55
(T) oil usage? Chriselectrics Panda (2012+) 21 24-01-2017 22:16
(T) Oil usage - Mobile 1 new life, One litre and no oil on dipstick??? Smartarse84 Stilo 33 29-01-2016 08:34
(T) oil usage... normal or not? dynamicsportchris Grande Punto 23 03-09-2011 14:56
(T) Oil usage sboy66 Grande Punto 2 17-02-2009 18:06
