I’ve searched but not found. Can anyone tell me the torque value for a 2006 1.2 petrol Panda 4x4?
Ta muchly
Ta muchly
should be in the owner manual
If the bolts have been greased then around 90nm will be far to High. Around 60nm is about right.
I have been using a small amount of copaslip on wheel bolts and hub to stop the wheels rusting on, since the 80s when I became a mechanic, it is common practice by garages and need only a torque reduction when fitting the wheels, and perfectly safe to do.Greased wheel bolts are dangerous. The threads would need to be fully cleaned. A high soldis anti seize paste should be OK but deffo not Copslip (too greasy) and its better avoided altogether.
