- Sep 14, 2009
- 19,492
- 3,294
Mine only ever catches on strange road cambers or with a full back seat. I have 500 springs and 50 tyres. It's a rare event so not worrying about it.
Before and after on my 100hp, Bilstein B6 19-235646
Is that the Eibach pro springs also? Any good?
I have this exact setup ready to go on.
Bilstein are the best ride quality by far though. If I work out a fix for the rattle I will let you know. Thinking if making a sleeve and have an idea of how to do so cheaply.
KYB are fine and Monro. Bilstein fit the wrong sized bush so they rattle like hell. Totally unacceptable!!!! Bilstein are the best ride quality by far though. If I work out a fix for the rattle I will let you know. Thinking if making a sleeve and have an idea of how to do so cheaply.
My 100HP at 85K miles the dampers were just beginning to fail. Well worth changing and a simple job front and back easy to do all 4 corners in half a day. Front pinch bolts can be stuck so buy new bolts all round. Soak with penetrating oil for a few days before doing the job.
Which bush do the Bilstein have wrong?
I though it was the Koni that had the wrong size.
Both the small bolt (top) and the large one (bottom are 2.5 mm too big) I have tried packing them out but its not working. I am now looking for tube sleeving. Failing this I am going to build the bolt up with weld and have them machined to the correct size. Its bloody annoying though.
KYB used on my Panda 100 were fine. Bushes however failed inside 3 years.
The bolts are 10mm so you need some 1/2" OD tube with 1.5mm wall thickness and drill it out to 10mm bore. Then cut to length with a pipe cutter and deburr. Job done.
DO NOT get stainless tube unless you have special drills and lots of flowing coolant.
This looks just the job 12.7mm OD x 1.2mm wall = 10.3 bore.
https://www.ebay.co.uk/itm/ERW-Round-Mild-Steel-TUBE-Pipe-9-Diameters-Bandsaw-Cut-Lengths-Trade-Supplier/292010905656?var=591008602580&hash=item43fd34d038:m:mhR-r-EoP_1tCju5bl_zzJQ
Call them to see if thicker wall tubes are available with the same OD.
Thanks. Is this on the rear shocks?
Yes rears are causing the problems. The Fronts are Monro and seem OK.
I’ve just swapped the rears for bilstein b6s and the holes where exactly the same size.
Cant say if Bilstein have changed them. They took about 3 months to arrive mind.
