Thread Tools
Old 05-03-2019   #1
100HP Seat Backs
Has anyone managed to swap the drivers seat back on their Panda for the passenger one? The other day the left side bolster collapsed on mine and can feel the metal frame underneath now. Its annoying as Id already replaced the entire seat when I bought the car for the same reason. My only other option is to fit some after markets OMP or Recaro seats but will lose the standard look plus Im sure where the seat belt socket would go as theyre obviously attached to the seat at present. Any ideas?
guywarrington is offline Reply With Quote Quote
Old 05-03-2019   #2
Re: 100HP Seat Backs
I will be watching with interest
Because I’ve the same problem
Agh321 is offline Reply With Quote Quote
Old 05-03-2019   #3
SPORTPACK50 has donated!
Me too!
SPORTPACK50 is offline Reply With Quote Quote
Old 05-03-2019   #4
what the hell are people doing to their pandas to make the bolsters collapse? my girlfriends are perfectly ok on hers and the car has done about 125,000miles.
dac69er is offline Reply With Quote Quote
Old 05-03-2019   #5
irc has donated!
You can repair them (foam glue and hessian, but they never seem to feel as comfortable.
If you do nothing, the covering will eventually get cut by the sharp seat edge.
The bases are an easy swap, the backs less so, but probably possible. The seat back adjuster rod is the awkward bit... not taken one apart yet, so not sure if the actual metalwork is handed or not.
Or you could remove the cover, cut and paste the good foam sides of 2 backs and reassemble.
irc
Panda Sporting MultiJet 1.3 "Diesel Weasel"
Panda Sporting MultiJet 1.3 "Pig"
Panda Eleganza Dualogic 1.2 "Magic Panda"
irc is offline Reply With Quote Quote
Old 06-03-2019   #6
Quote Originally Posted by dac69er View Post
When getting in/out, I take my weight on the hand brake handle. That reduces scrubbing across the seat fabric. Ive done that ever since the 1980s when I had a car with velour seat covers. The "inside" seat bolster got ruined by hand pressure scrubbing the pile as I got in/out.
If you have the seat so close to the steering wheel that the frame gets forced as you get in/out, then you need to think about how you use the pedals. If larger people use the car then slide the seat back so they dont have to strain the seat when they use the car.
Many short people drive by lifting their whole leg. This tiring and gives poor car control. Legs should be fairly straight with ankles working the pedals. If your feet are too small for that, put some plywood or layers of corrugated card under a floor mat. You should not be lifting your whole leg to operate the clutch
If the seat frame is damaged you could carefully remove the seat upholstery and get the frame welded. Check costs with a trimmers.
DaveMcT is offline Reply With Quote Quote
Old 06-03-2019   #7
Slovakia
Another option is to fit in a seat from newer Panda 312/319. Some info here.
SkAtPanda is offline Reply With Quote Quote
Old 06-03-2019   #8
Quote Originally Posted by DaveMcT View Post
You should not be lifting your whole leg to operate the clutch.
Only sideshow Bob would able to achieve this!!!
Brake and accelerator fair enough, but not the clutch!
Old 07-03-2019   #9
My ex had her seat rammed right up to the steering wheel she said it was the only way to reach the clutch. Not surprisingly she was painfully slow at parking into tight spaces and hill starts stressed her out. All she needed was a filler pad under the driver's side floormat then she could sit further back.
That made getting into and out of the car a lot easier (and less damaging to the seat) though she always had to slide the seat forwards and back.
Old 07-03-2019   #10
narbles has donated!
Quote Originally Posted by irc View Post
This is what I'm interested in. I found another thread for a different model (Cinquecento) talking about how to remove the cloth which looks like it might be a similar process for the Panda 100 (sorry can't post URLs yet...).
I'd like to know more about this cutting of the foam. My bolster is off to one side with metal that you can feel. Are you suggesting getting additional foam?
narbles is offline Reply With Quote Quote
Old 07-03-2019   #11
irc has donated!
I repaired the driver's seat in my Panda Sporting with Hessian and foam glue after the foam split.
It was OK, but I could always notice it.
I was suggesting cutting the whole side off a scrap seat foam, and using it to replace the equivalent bit of split foam.
That way you could glue the 2 bits together somewhere less noticeable (like where the side part joins the thinner back part).
Then you wouldn't feel the repair every time you sat down, which you probably will if you just glue the split back together.
(Apologies for the rubbish description, but hope you get the idea)
irc
Old 15-03-2019   #12
Thanks for the info! I might give the above a go as it's really beginning to annoy me plus I heard a spring go a couple of days ago...it's not like I'm a 'heavy' guy and can only assume the seats are just poor quality. I've always said the Panda is made up of cheap materials put together very well, so might be true! I know two other people with Pandas (albeit not 100HPs) and the bolsters are the same and have less than 60k on. Weirdly it always seems to be the left shoulder one...maybe the driving position is slightly off centre (not a major surprise on any Italian car). I guess my other option is to get some half leather dark grey ones out of a 500 Sport and modify the rear bracket which might look ok. They seem more padded on those.
Old 15-03-2019   #13
irc has donated!
Saw a damaged Ka with plain leather seats which would have looked OK in my Panda, but someone bought the whole car before I had the chance to make an offer on them. Not keen on having a "500" logo on my seats. Fine in a 500, naff in a Panda.
All the cloth ones I've seen are a bit "out there" for me.
Still looking...
irc
Old 17-03-2019   #14
Get them repaired and reupholstered.
Push the boat out for a 500 Abarth interior -
https://www.ebay.co.uk/sch/i.html?_f...seats&_sacat=0
Old 18-03-2019   #15
There are some plain 500 Sport seats that are half leather with like a ribbed cloth in the centre with no 500 logo. I missed out on some for 100 the other day on eBay.
Thread Tools
(G) 100hp Wing Mirror Backs Dalespitfire Panda 1 12-02-2009 08:26
backs are in scottyJTD (FS) Car Chat 14 08-06-2007 22:47
TROUBLE with the backs going in!! scotty FIAT Boo Archives 0 23-05-2007 02:49
LOW OR HI-BACKS STEVE FIAT Boo Archives 4 22-06-2005 22:03
Piggy Backs danny FIAT Boo Archives 7 21-07-2004 20:29
