This is a fix for an 04+ panda with climate where the heater flap pin has snapped off.
note 1. there is no need to either get or look inside the heater box.
2. avoiding turning on the ignition while the cog wheel is disconnected from the flap motor may keep the motor in sync and obviate the need to reset the climate system.
3. apart from the pin this is a robust and strong flap and takes the self tapper very well.
4. the teeth on the cog wheel perform no function whatsoever.
5. with practice, before removing anything, it is possible to reach carefully over the top of the flap motor and feel if the cog wheel is anticlockwise against the top stop when it should be blowing hot air. if it is and you are getting cold air the pin is almost certainly snapped. You can also check the movement of the cog wheel by changing the temp. setting just remember it doesn't react very quickly.
6. do not force the cog to turn in the motor, it contains a double worm reduction drive and won't accept reverse torque, if you have disregarded 2 above and need to turn the motor socket to realign the cog wheel it can be done with a 9v battery connected to the pair of pins in its electrical connector, be careful not to short anything.
7. The flap only has an operational arc of only 70 degrees or so and is also limited by the gearwheel stops on the heater box and the stop on the outside of the flap motor. Internally the motor will go around all day hence 2 above.
8. The self tapper/chipboard screw I used was 50mm by 6mm max thread diameter with a 12 mm head.
Here goes, remove fuse box cover(2 philips), steering column lower cover(3 philips), gear lever gator(prise upwards), gear lever surround(2 pozi and prise upwards), RHS footwell panel(2x 5mm allen), lwr. gear selector panel(2 pozi + 2 allen). Then remove dash bolts from inside fuse cover, under dash panel by left shin and in front of gear lever. strap dash panel back to seat frame and you should have enough access.
Remove the flap motor, a square box held by 3 very small hex bolts. The cog wheel is held between the motor and the flap pin by friction only. If the cog wheel has a small piece of plastic stuck in it you have found the problem(Google “panda owner loses cool”).Remove the remains of the pin.
File or grind the head of a suitably large self tapper to fit the socket of the gear wheel. Drill small (maybe 1.5 mm) pilot hole straight and square into the flap through the hole where the gearwheel fits, drill hole a little low as the flap is centered by the pin and gearwheel. Insert self tapper, the philips head on mine worked well until he last few turns when I used a pliers.
Test with cog wheel and adjust screw rotation until cog wheel can rotate fully between both stops. Mechanically this is very strong, the tricky bit is getting the pilot hole straight and not too large and synchronizing the rotating parts, once again see point 2 above.
Straying outside my area of expertise, the climate reset procedure involves pressing auto and windscreen defrost buttons together soon after switching on the ignition, possibly with temp on lo first, holding until temp reading stops changing and waiting while it self tests.
Good luck.
