In a word yes. Take the heatshield off if you have on then unbolt the manifold from the head. Ease it off the studs once you've removed the gearbox to exhaust bracket. Move the whole lot to the near side. You should have enough room to remove the sump. They are really well stuck on with silicone and take some getting off. Have fun!
En una palabra sí. Retire el escudo térmico si lo tiene puesto y luego desatornille el colector de la cabeza. Quítelo de los espárragos una vez que haya quitado la caja de cambios al soporte de escape. Mueva todo el lote al lado cercano. Debe tener suficiente espacio para quitar el sumidero. Están muy bien pegados con silicona y se quitan un poco. ¡Divertirse!
Hola a todos, ¿alguien reemplazó el cárter del auto mencionado? hay que desmontar el multiple de escape? Cualquier ayuda muy apreciada, Gracias por adelantado.
Hi all, has anyone replaced the crankcase on the mentioned car? Do I have to remove the exhaust manifold? Any help greatly appreciated, Thanks in advance.
Hello
did you finally do the job?
Although it’s technically possible, it’s not recommended. The oil pick up pipe is easily damaged. It would be difficult not to smudge the bead
I watched a garage change a Punto sumps which is a similar setup
They also dropped the exhaust to make the job easier.
