Old 11-02-2015   #1
Knocking noise at the rear
Took the car in to my local garage today to try and find where this knocking is coming from?
Rear shocks changed for bilsten ones about 9k miles ago, bushes are a little worn but not to bad, bump stops look like they are in good condition. Any other ideas?
Mechanic wondered weather the spring cups should have some sort of rubber on them?
doug7126 is offline Reply With Quote Quote
Old 12-02-2015   #2
Re: Knocking noise at the rear
Having just read all the other posts on this I have just ordered some poly bushes from demo tweeks and will fit them and see if it makes any difference next will be the bump stops if that doesn't work, will try the 500 abarth versions as they are 11 quid each cheaper than the panda ones.
Old 12-02-2015   #3
Trader Rating: 1
portland_bill has donated!
Check the front drop links. When they go, movement of the rear suspension affects them and the noise often sounds like it is from the rear.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 12-02-2015   #4
Will get them to check them is it a easy fix?
Old 12-02-2015   #5
Trader Rating: 1
Simple and cheap.
Old 15-02-2015   #6
tinmar49 has donated!
Check the bump stop prices at shop4parts. I was surprised how cheap they were, the Arbarth ones may be the same p/number.
tinmar49 is offline Reply With Quote Quote
(G) nearside rear knocking noise amazin09 Punto (Mk2/2b) 4 10-07-2010 01:46
(G) knocking noise from the rear? N344HLU Punto (Mk2/2b) 3 09-02-2010 14:39
(G) Rear knocking noise - yes I know we've heard it all before but.... Phil_ Cinquecento / Seicento 13 03-01-2008 16:26
(T) high pitch noise from engline and knocking noise in rear elcrack Punto (Mk2/2b) 12 08-11-2005 22:53
(T) Help knocking noise from rear stevehickey6 Punto (Mk2/2b) 21 13-10-2004 06:11
