You sound like you have lots of experience with modifying drivetrains to fit different cars so if i was you i would use this extensive knowledge to build a 'special' panda using a 100hp as a basis and then show us all how you did it.
The 1.4 that we talk of is a 1.4 8v from a grande punto that would give about 20hp extra but it would slot straight in with no ecu driveshaft changes etc. I'm not too sure on specific 100hp differences brakes will be different ecu will be different I haven't seen the driveshafts but I'd imagine they were the same. A punto 16v engine would be a lot easier to source but will be the 90-95bhp version. The fire (8v) and superfire(16v) engine and gearboxes have the same mounting points heck you could even keep your box as the bell housing is the same
