Just modded one of those tiny blue crappy ELM327 BT units for the panda and MES as I need to send my CanTieCar unit back for a BT issue. Didnt want to use adapter leads,,
Heres what you need to do - you will get all ECU's on registered version apart from Airbag.. Will work with almost any ELM327 unit...
Warning - dont attempt unless you are reasonably competent with a soldering iron..
First, find the resistor that most of the chinese crap adapters have between pins 6 and 14 (it is 120 Ohms usually) - remove it.. (Crunch it)
Now solder new leads from pin 7 to pin 1 and 9.
There ya go..
Plug and prey..
The one I modded was the tiny BT unit with clear blue plastic, I would not recommend that one unless you have a very good magnifying glass, the resistor is in the middle of the board and VERY difficult to get to, the soldering is also a nightmare..
The other units (larger ones) are much easier.
This will give you the equivalent of 327 and 327 with green lead.
No swapping or changing.
There ya go..
Plug and prey..
