General Horn location
Behind the front bumper to the left of the badge. Hard to access, but I managed to fit 2 Hella Supertones without removing the bumper. Also the connector will need cutting off as it's a weird plastic one, get some spades crimped on there.
Its behind the front grille (or bumper on the 100hp as the grille and bumper are incorperated).
You'll probably have to relocate the horn if you upgrade is anything to different to the OEM horn, as I doubt a standard airhorn will fit in the same location, although I could well be wrong.
Jon.
Thanks for the advice, found where the standard horn lives & changed it for a set of "Airhorns". (y)
I'll have to let the dealer know when they come to do a MOT as the horn is slightly louder (y)
I'll be at Wheels Day (22nd April) & Brooklands (30th April) car shows if anyone wants any advice:
All installed & fuse'd so no chance of a fire etc. :)
