Old 11-12-2008   #1
How do I adjust the window washers?
Hi all,
I'm wondering how to adjust the window washers on my new panda dynamic. There are three lovely jets on each side, but they all just clip the top of the windscreen before shooting over the roof. I have looked but there seems to be no way of adjusting them as they appear to be just pre-drilled holes rather than adjustable jets. any suggestions?
thanks
bobajob is offline Reply With Quote Quote
Old 11-12-2008   #2
Sei Sporting abarth
FIREsporting has donated!
Re: How do I adjust the window washers?
I normally use a pin inserted into the nozzle to allow a bit of leverage to direct the jets, then adjust them to the point you want them.
/F/I/A/T/Sei Sporting ABARTH
FIREsporting is offline Reply With Quote Quote
Old 11-12-2008   #3
Banned
If you look on the other side, there should be a tiny slot where you can put a screwdriver and adjust it to the right angle, only a minor adjustment is required.
DraigFlag87 is offline Reply With Quote Quote
Old 14-12-2008   #4
thanks very much found it :-)
(T) Rear Window Washers ! jonesman9 Punto (Mk2/2b) 6 14-02-2007 01:08
(T) Window washers not spraying properly Scorg Bravo / Brava 5 25-01-2005 01:33
(T) Window Washers/12v Power/Console Buttons DarkMonk Punto (Mk2/2b) 5 14-12-2004 00:47
(T) Fiat tipo window washers excossack Tipo (Classic) 1 09-09-2004 11:00
(G) window washers blackJTD Stilo 8 13-05-2004 01:41
