Wow, 4 weeks already! The coolant level dropped a little bit again so I did a bit more reading and found a helpful tip from the Punto section to fill the expansion tank up to the very, very top. I did that and, this time, coolant came out of the bleeding screws of it's own accord. I did the rear one first and then the one on the radiator until the coolant level was correct. The level now seems to be holding steady. I felt the hoses and radiator and could feel when the thermostat opened. I need to find my OBD2 scanner so I can check if temps are matching spec. Does anyone know offhand what temp the cooling fan should kick in at?
Yeah, this is a Scottish Panda and it's surprisingly rusty in places for a 5 year old car. Next year, I'll do a major rust prevention treatment on it but I'm focusing on the immediate problems just now. I've just replaced the front brakes (they had rusted due to previous owners low mileage) and I need to change the gasket between the exhaust down pipe and middle section to get it through it's MOT next week.
Now, a partial apology to the not so high iq fast fit garage! The receipt shows they charged £80 for a new flexi pipe. I realise now, they only changed the flexi bit of the middle section of the exhaust - they cut it out and welded in a replacement!
Anyway, I bet it was those ham fisted guys that broke the fan cowling in the pic.
