| Thread Tools |
![]() | #1 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 ![]() | 58 Panda auto gearbox no drive I have a 2008 Panda with autotransmission. Recently when coming to a stop at a junction I have noticed the gearbox drops into N and the transmission light comes on dashboard with a pinging noise. The display reads no gear available. No matter if I try manual or auto, pressing the E button, switch off Engine it will not drive. Had it taken to garage that reset ECU and said the fault may return. It duelly did. Any ideas to what the fault could be? It happened several times previously but I managed to get it working by flicking the gearstick between auto/manual. Seemed to free itself but this no longer works.
![]() | #2 |
Moderator Join Date: Mar 2010 Location: Dorset
Posts: 7,847 Thanks: 820 Trader Rating: 0 ![]() | Re: 58 Panda auto gearbox no drive Hello and welcome to the forum. Sorry to hear you're having difficulties. How long have you owned the car? I have a 2008 Panda with autotransmission. Recently when coming to a stop at a junction I have noticed the gearbox drops into N and the transmission light comes on dashboard with a pinging noise. The display reads no gear available. No matter if I try manual or auto, pressing the E button, switch off Engine it will not drive. Had it taken to garage that reset ECU and said the fault may return. It duelly did. Any ideas to what the fault could be? It happened several times previously but I managed to get it working by flicking the gearstick between auto/manual. Seemed to free itself but this no longer works. Have a read of this thread from the 500 section. Last edited by jrkitching; 13-01-2018 at 09:16. |
![]() | #3 | ||
Posts: 16,655 Thanks: 585 Trader Rating: 0 ![]() | I have a 2008 Panda with autotransmission. Recently when coming to a stop at a junction I have noticed the gearbox drops into N and the transmission light comes on dashboard with a pinging noise. The display reads no gear available. No matter if I try manual or auto, pressing the E button, switch off Engine it will not drive. Had it taken to garage that reset ECU and said the fault may return. It duelly did. Any ideas to what the fault could be? It happened several times previously but I managed to get it working by flicking the gearstick between auto/manual. Seemed to free itself but this no longer works. Bleed-purge the fluid through the system Then reset all the necessary parameters.. Its a relatively simple job in principle.. but Impossible without the correct knowledge..and software. Charlie . Oxford - Cardiff
![]() | #4 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 ![]() | Re: 58 Panda auto gearbox no drive Not sure what the garage did apart from reset codes. Im going to take car to a fiat specialist and see what they diagnose.
![]() | #5 |
Posts: 533 Thanks: 41 Trader Rating: 0 ![]() | Re: 58 Panda auto gearbox no drive It does sound like the symptoms of a lazy pump motor (if no leaks and no clutch slip/noise.) Certainly worth checking if "expert" advice is not actually expert, which, unfortunately, is often the case. Motor brushes can wear down, and can be replaces (try an Alfa Selespeed expert) or replacement motors can be found (although pricey and you usually need to swap some parts over to the new motor). Pump motors are same as used on some Alfa Selespeed, Ferrari and Maserati systems.
__________________ irc Panda Sporting MultiJet 1.3 "Diesel Weasel" Panda Eleganza Dualogic 1.2 "Magic Panda" Panda Active 1.1 "Moley" Panda Active Eco 1.1 |
Thread Tools | |
![]() | demag | Idea | 2 | 22-02-2015 23:17 |
![]() | TheHiggsMoron | Punto (Mk2/2b) | 7 | 19-12-2009 11:33 |
![]() | Astro500 | 500 | 45 | 18-09-2009 17:11 |
