Is it getting fuel does the exhaust smell of fuel after trying to start it?
yes, but only a little but it doesn't smokeAlan.D said:Is it getting fuel does the exhaust smell of fuel after trying to start it?
well the back sticks out to the left and the front remains straight as far as i could tell... i must confess i only really noticed it once i had the pics on the computer... as i didn't physically get under the back end of the car... just stuck the camera down there... i will have another look tomorrow.Alan.D said:That bit of the crossmember looks to uniform to be hit and is probably extra room for the exaust as it bobbs up n down. The leaf spring is it def broken?
Alan.D said:there should be a metal ring round them that holds them in place I take it the front part is straight in comparison with the back.
Alan.D said:I have a couple of spare shocks in better nic than those as it looks a bit worrying on the securing ring. There is a problem with the gearlever cover but that's easy sorted.
Alloy looks smaller diameter next too it... says it's 13 x5.5 but looks different.christopher watson said:Nice alloy, but i prefer the white steel wheel.
Alan there's a couple of guestrooms you can use to rest your eyes before in the unearthly set off time on the 27th (3am? or something). I suspect it's probably quicker to get to Carlisle from mine than yours anyway.Alan.D said:Looks Good Tony those alloys are :yum:
The grease nipple is a tight fit as the pressure is quite high when pumping the grease through and should be tight.
I was thinking that on the 26th I'll come down in the BMW early and we can have a go at the Selecta, and maybe some bits on the Sisley as I have a grease gun that will fit and poss bring down the old shocks for you to look at if you want them etc then come back up here ready for an early rise to the ferry for the NIIMC meet.
That's very kind Alan but i don't think the panda has enough juice to fit a DVD player and screen.Alan.D said:Oh! and I've got both Italian Job films on the DVD changer
OK the joint is greased the dampers are swapped... will post a pic tomorrow.Alan.D said:I was thinking that on the 26th I'll come down in the BMW early and we can have a go at the Selecta, and maybe some bits on the Sisley as I have a grease gun that will fit and poss bring down the old shocks for you to look at if you want them etc then come back up here ready for an early rise to the ferry for the NIIMC meet.
