Old 21-01-2021   #1
Serbia
VSS not working 1.2 16v conversion
A question for anyone who did a 1.1MPI / 1.2 16V conversion on a Panda 141. My VSS (vehicle speed sensor) isn't working at all. The question is, is it the incompatibility of the sensor because we used a complete Fiat Bravo 1.2 16v engine loom and ECU but left the Panda's VSS (a combined sensor) or is it something else maybe. The engine is from a 2001 Fiat Bravo 1.2 16v (59kw). Any help would be greatly appreciated.
Alen992 is offline Reply With Quote Quote
Old 22-01-2021   #2
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
Re: VSS not working 1.2 16v conversion
hmm crazy as it sounds, you could also ask in the Cinquecento section. i think they got the RPM gauge to work by tapping into a coil live..
Dragon Man is offline Reply With Quote Quote
Old 22-01-2021   #3
varesecrazy has donated!
Quote Originally Posted by Alen992 View Post
A question for anyone who did a 1.1MPI / 1.2 16V conversion on a Panda 141. My VSS (vehicle speed sensor) isn't working at all. The question is, is it the incompatibility .
Wheel speed( gaarbox)... or engine speed ?
Old 22-01-2021   #4
Serbia
Quote Originally Posted by varesecrazy View Post
Wheel speed (gearbox), my rpm is working.
Old 22-01-2021   #5
Try a bravo sensor.. they must be cheap now..
Thanks Alen992 thanked for this post
Likes Alen992 liked this post
Old 22-01-2021   #6
Serbia
I'm planning to. I would just like to know if that's the problem.
Old 23-01-2021   #7
Not a Guarantee..
Do you know if speedometer : odometer was working with the original motor?
Old 24-01-2021   #8
Serbia
The speedometer was and is working now, because its mechanical with a cable. Im just not getting a speed reading to the ECU and OBD.
Old 2 Weeks Ago   #9
Serbia
Ok, so a little update, i found that when we were doing the conversion we severed the power supply per ignition wire for the VSS, the negative is connected, the only thing that i need now is if someone could provide me with the information which pin on the ECU is for the VSS signal? The ECU is Bosch ME73H4.
Old 1 Week Ago   #10
Serbia
Anyone?
(T) Punto Sporting VSS Speed sensor wiring 1.4 16v converted codereader Punto (Mk2/2b) 12 19-11-2017 19:45
(T) Vss location and wiring modification help for Punto 188 mk2 1.2 16v elx speedgear non sandaru Punto (Mk2/2b) 33 19-11-2017 19:29
(T) 1.1 8v to 1.4 16v conversion sbrads Cinquecento / Seicento 1 03-03-2016 20:22
(T) what do I need with 1.4 16v conversion Mount Cinquecento / Seicento 6 21-05-2009 13:57
