So obtained a Punto 55/60/75/90 alternator in 75 Amp trim
Looking at a 1993-1997 Pulley to match.
Think its 73502725
Which also covers 46438708 55181196 apparently.
Anyone confirm?
just use the standard punto 55 / 60 / 75, cinquecento sporting.. or anything with the non-aircon 8 valve FIRE engine bottom pulley. the old style panda single V belt will sequel.. but if you use the multi V belt the puntos use with will be fine.. just 3x 13mm bolts on the crank to get it off.
they all use the same width belt
i too have the punto 75amp alternator on my panda with the 999cc engine. when i have over 1 Kw of light shining forward.. i kinda need the amps
