So a small side job I attempted to spec all the required HT bolts for my 4x4 rebuild.
I guarantee nothing here but as I replace them any if any seem odd I will advise.
Work In progress.
Hexagon Heads zinc plated. I picked 8.8 Spec.
Front Suspension Part No Qty Size Thread Form
Bolt front suspension to chassis rear mount 16190334 2 M10 x 1.25 x 75 Plain Shank
Bolts shock to front hub 15971334 4 M10 x 1.25 x 75 Plain Shank
Pivot bolt control arm to front bracket 16242321 2 M10 x 1.25 x 85 Plain Shank
Pivot bolt backing plate 16043424 2 M8 x 1.25 x 20 Full Thread
Rear Suspension
Rear Shock Bolts 15541024 4 M12 x 1.25 x 60 Plain Shank
Leaf Spring Mounts 11288024 8 M10 x 1.25 x 60 Plain Shank
Front Bolts Rear Leaf Springs 4402580 2 M12 x 1.25 x 110 Plain Shank
Hub to Mount 11227924 4 M10 x 1.25 x 28 Full Thread
Engine & Box Mounts
Engine Mount Bolts 16135624 4 M8 x 1.25 x 20 Full Thread
Engine Mount Bolt (offside) long 15972021 1 M10 x 1.25 x 110 Plain Shank
Lower Gear Box Mount Bolt 11227924 1 M 10 x 1.25 x 30 Full Thread
Gear Box Mount Lower Long Bolt 16042821 1 M10 x 1.25 x 10 Plain Shank
Lower Gear Box Mounting 15972424 1 M10 x 1.25 x 130 Plain Shank
Lower Gear Box Mounting Long Bolt 16043934 2 M8 x 1.25 x 35 Plain Shank
Others
Engine Protector Front 11617524 4 M8 x 1.25 x 25 Full Thread
Engine Protector Rear 7543095 4 M8 x 1.25 x 25 Full Thread
Prop Shaft front 4393157 6 M8 x 1.25 x 46 Plain Shank
Prop shaft rear 16287321 4 M8 x 1.25 x 30 Plain Shank
Front Brake 46417125 4 M10 x 1.25 x 30 Full Thread
Steering Arm C bar 16044024 4 M8 x 1.25 x 40 Full Thread
Steering Rack Clamps 16043634 4 M8 x 1.25 x 42 Full Thread
Will also need some nyloc nuts, plain nuts, plain washers and spring washers.
I just ordered 10 off of each nut and 20 of each washer.
Part numbers from
https://www.fiatdalys.lt/en/catalog/groups/2R/0/0/M6,M7,M8/0/GD
As Eper is less that reliable.
As to suppliers well Fiat of course but I selected most from
https://www.margnor.co.uk.
Came in 3 days all separately packed and labelled.
Some rounding up required to match all the sizes.
You may have to measure a few to confirm best fit.
130mm length M10 came from Amazon.
Also picked up a box of assorted stainless full threads for non critical items.
Whole lot was just over £50.
Good hunting!
Work In progress.
Rear Suspension
Engine & Box Mounts
Others
Part numbers from
Good hunting!
