Thread Tools
Old 06-12-2017   #1
Strut to control arm issue
I have fitted new front struts and 'control arms' ( the pressed steel uprights that hold the lower ball joint) to my 1991 4x4 .
I noticed the M12 bolts that came out were slightly too big for the holes in the new control arms. Turns out they are not exactly M12 and so I can only guess for some reason a previous owner had fitted oversize bolts. Seems odd. No matter, I found some used originals and tightened them up to specified torque in manual (44ft/lbs). However the strut and arm still have play/movement , noticable when the car is driven. Alarming as it changes the camber drastically. Tightening the bolts to 140ft/lb+ eventually solves the problem , but that doesn't seem quite right.
Question: Were there different arms and/or struts for more than one bolt size? (I can't get on Eper anywhere to check. )
I definitely have 4x4 control arms.
Bolts don't appear to use washers, so just relies on nylocs to stay tight. Unusual.
Anyone else had this experience?
(I seem to remember VW Golf had similar design but with eccentric bolt to adjust camber.)
pan127 is offline Reply With Quote Quote
Old 06-12-2017   #2
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
Re: Strut to control arm issue
Sisley '89
Formula '91
W123 230CE '83 - project for sale £400
Subaru Legacy GT-B '98
kolza is offline Reply With Quote Quote
Old 06-12-2017   #3
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
What do you mean by Strut?
I'm not getting the hole juice.
Track control arms are the same for 2wd and 4x4.
Shock absortbers are different same as hub cariers as well.
Thanks Sjvarley thanked for this post
Sisley '89
Formula '91
Old 06-12-2017   #4
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
Often resellers don't know that 4x4 are different ad list them as compatible.
There should be some pretty tick washers there.
Example photo just to make it easier, please ignore my lower ball joint as it is custom one.
Sisley '89
Formula '91
Old 06-12-2017   #5
panda1408 has donated!
Jacob I think pan127 means the shock absorber when he says strut and the hub carrier when he says track control arm.
The 4x4 uses M12 bolts, 2WD uses M10, both a fine thread. No washers fitted. Had someone fitted half inch UNF bolts and are you sure your new bolts are M12?
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 06-12-2017   #6
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
Sisley '89
Formula '91
Old 07-12-2017   #7
Thank you for these most helpful replies.
To clarify, yes I am talking about 'shock absorber' to ' hub carrier'.
Yes, someone had fitted !/2inch UNF bolts ( 12.5mm dia) .
Unfortunately I seem unable to open the link kindly provided to eper.
The good news is I appear have the right size bolts (M12 fine ) , hub carriers and shocks. (If I had 2wd carriers and shocks the holes wouldn't be big enough).
There were no washers anywhere to be found on mine. I have examined a scrap assembly from another old 4x4 and that doesn't appear to have any washers either.
So what are the washers shown in the photo (kindly provided by Mr Kolza) for?
Are these to act as shims between hub carrier and shock absorber? Seems unlikely as there is very little clearance.
How much torque do you guys like to apply to these M12 bolts to keep them secure?
Thanks Joel
Old 07-12-2017   #8
Those thick washers are for the M10 bolt that holds the lower arm to the body of the car, nothing to do with the upright I believe.
I couldn't give you a torque figure for the bolts but fully tight with a standard size 1/2 inch ratchet should be fine.
The only problem I have had with the carrier moving is on lifted cars where the top hole needs to be slotted to get the correct camber value. And then it has only moved after some serious off roading, never just driving on the road.
1982 Panda 45
Thread Tools
(T) Control arm front right Luckor10 X1/9 12 15-10-2017 16:42
(T) Steering Control Arm BrianMcL Croma 1 01-11-2015 16:25
(T) Removing control arm Happybubbas 500 8 09-05-2015 22:02
(G) Regarding top strut bearings and wiper arm thepieman Grande Punto 3 28-10-2011 23:04
(T) Control arm bushes rawill Uno 5 30-11-2009 06:03
