Thread Tools
Old 15-05-2018   #181
Re: Just started and could do with some 4x4 help.
Ok when do we get to see the beast ???
Sjvarley is offline Reply With Quote Quote
Old 15-05-2018   #182
So in the sun the colour change continues. Mirror looking better now and the rest of the side trim clips fitted. Not sure if it was the paint thickness or the clips but had to put a small cut in the point to get the pin to go all the way through.
Trim goes on.
Here’s the one that was broken. Looking much better.
Front and rear glass refitted. Admit I had some professional help just in case. Thank you D700SKX for your donation may you rest in peace.
Plan is to make it as waterproof as possible so I can get on with the interior if the weather goes downhill.
Now I will do a write up just on the lift kit later but here’s the rear shackles ready to fit.
Lube the new bushes.
Then fit the springs.
Nice new bushes in the front and new bolts.
Decided to fit the back axel so I have some floor space in the garage.
Filled with new oil first!
Going in well!
Nice fit!
Rather useful tool loaned from a good friend. Means I don’t need another pair of hands.
Think I have created a monster?
Its going to be taller than the Land Rover when the wheels go on?
Some new seals on the front vents.
Tight fit!
Satin coat for these I think?
Lots of parts to the front aerial fitting… Think that might be going to the rear?
Fitted some more duct tape to the top rail and fitted the trim (coat of gold for blingness) with a mallet.
Interior is ready!
Hope to post some pics tomorrow.
Thanks kestrel4x4 thanked for this post
Likes AndyPanda4x4, kestrel4x4 liked this post
Derek C is offline Reply With Quote Quote
Old 15-05-2018   #183
Patience is a virtue?
Welcome round any time.
If it wasn’t for work I’d finish the build in a few days but then I couldn’t afford the next stage.
I will get some all over shots towards the weekend as tasters.
Alternator pully is doing my head in at the moment. Think I will need a spacer or I have to machine the alternator mating faces. Not serious but as the parts are all FIRE compatible cant see why the belt has a 5mm offset. Will shove some pics up just in case they supplied the wrong pulley.
Thanks Sjvarley thanked for this post
Likes Michael Dranfield liked this post
Old 16-05-2018   #184
Vee belt or 4 groves ???
Old 16-05-2018   #185
Vee belt can be a little out but a grooved pulley should be lined up. With a straight edge
Old 16-05-2018   #186
Have you had the crank pulley off and inverted it ?
Old 17-05-2018   #187
Quote Originally Posted by Sjvarley View Post
So its a Punto Mk1 1.2 8V alternator and Pulley.
Not the best images but the belt is looking stressed as the alternator seems to be about 5mm more forward of the pulley.
Given the mass of the pulley I'm not keen on a shim behind the pulley.
Face here parallel to the block.
Allowing 2.5mm for the belt edge to the alternator pulley face gives me 4.5mm offset (negative) on the main pulley.
In my head the alternator needs to come back a bit...
I know 4 groves are tough but this looks like a failure awaiting a date.
Old 17-05-2018   #188
Just a few 'so far' shots.
Likes lukmek, AndyPanda4x4 liked this post
Old 17-05-2018   #189
ITALIAN PRIDE
kestrel4x4's Avatar
kestrel4x4 has donated!
Italy
WOW DEREK !!
Incredible job !!
Few times in my life I saw a restoration like this one !!
Panda 4x4 1987 EVO
Panda 4x4 - The best car for Alpen drive !!!
Ambassador of Panda 4x4 Off Road Club Italia Forum
kestrel4x4 is offline Reply With Quote Quote
Old 17-05-2018   #190
Quote Originally Posted by kestrel4x4 View Post
WOW DEREK !!
Incredible job !!
Non e restoration
evoluzione
Likes kestrel4x4 liked this post
Old 17-05-2018   #191
Some amazing work by Mark and his good lady at Hampshire Trimming.
http://www.hampshiretrimming.co.uk/
Steam Punk inse
rts from ApertureArtistry
Old 17-05-2018   #192
Alternator. Use a 4pk belt not 5 then off set the belt by a groove Air intake. ??? Reversed. Or intentional
Old 17-05-2018   #193
panda1408 has donated!
You may want a Panda SPI crank pulley, that has the crank sensor ring on the inside so may give the right alignment. Just a guess though. The belt will not last long as it is.
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 18-05-2018   #194
Regret is a 4 already.
Intentional - Think forced air will have little effect...probably more dead bugs...
Old 18-05-2018   #195
Quote Originally Posted by panda1408 View Post
Thanks! Will have a look.
Not even going to start it like that.....
Thread Tools
Getting started................................ madisonswift Newbie Central 4 17-11-2014 15:18
How to I get started? Simmy101 Newbie Central 2 14-09-2013 13:36
(G) Oh OH, it's started. anc Cinquecento / Seicento 0 27-04-2013 18:23
Punto (Mk2/2b) just started :) doofelx Newbie Central 6 10-06-2012 21:30
(G) I've started Stuartl Panda (Classic) 13 13-11-2007 15:20
