you need to disconnect the vac pipe from the dizzy and block it off then adjust the tick over to 850rpm and then you can set the timing. my book says 2deg btdc once you have set it reconnect the vac pipe and reset the tickover mine "pink's" when set at 2deg though my mate at fiat told me to set it at 0deg which I have and the pinking has gone.
