Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Panda Twinair Enginebay Servicing<!-- google_ad_section_end -->
Air Filter. Spark Plugs
Published by varesecrazy
08-08-2021
Difficulty Level: 2
User Rated:Unrated
Access
To gain access you will need to undo :
The small air feed hose.. 10mm Hex bolt..(like a horn bracket..just swing bracket)
Large feed hose .spring clip (tool required)
2 x 10mm hex bolts.. retaining airbox
Remove all of those and the air filter casing can be lifted free
There is a moulded spike that retains it onto a bracket at rear of engine
Contents
<< <    Next Page: Air Filter element (Page 1 of 2)    >  >>
Old 08-08-2021   #1
varesecrazy has donated!
Pics didnt load..
Bolts and clip for retaining airbox
ID:	219430   Click image for larger version
ID:	219432   Click image for larger version
Old 08-08-2021   #2
Airfilter
Screws removed
Debris to clear
Moulded mounting spike
A sneaky peek at a sparkplug too
ID:	219434   Click image for larger version
ID:	219436   Click image for larger version
Old 17-08-2021   #3
Sparkplugs
With the air filter removed access is pretty simple (better than a FIRE)
A Small screedriver to prise the yellow clip from the wiring plug
Then remove plug
ID:	219621   Click image for larger version
Old 17-08-2021   #4
I used a deep plug socket and a bar to undo the plugs.. one was TIGHT one was just snug.. 'suoposedly'fitted by the selling garage @16k...so had covered @8k
Undo the M6 bolt (10mm head)
Twist and pull the coilpack.. it has a rubber gaitor seal.. it could be stuff to pull.. but should twist o.k.
Undo the plug with the extended socket
Use the telescopic magnet to withdraw the plug
ID:	219624   Click image for larger version
Old 17-08-2021   #5
Re: Panda Twinair Enginebay Servicing
Lowering the new plug in on the magnet..
Try and rotate it in to start on its thread
Then pull it free from the magnet (you can always use a screwdrived to keep the plug in the bure as you withdraw the magnet )
Put the socket back on the plug.. wind it in by hand
TIP: once 'snug'.. back it out 5 or 6 turns.. if it goes free.. you were cross threaded
If its still straight and firm.. you are square in the thread
Then wind it down with you torque gauge
Twist and push the coil pack back onto the plug.. then fit and torque the M6 securing bolt
Clip in the wiring loom
Old 17-08-2021   #6
Some of the tools.. nothing flash
The red handled pincer..nail pliers
are perfect for refitting the large hose clip.. so it climbs back over the clip and latches
Old 17-08-2021   #7
Air filter lid
Large hose clip, see where the 'hook'can ride over and lock
ID:	219627   Click image for larger version
Old 17-08-2021   #8
I discovered the Panda '63plate is EURO6 ECU
Wheras my Punto TA '13 plate is EURO5 ECU
BOTH 85hp..and both 99 emissions.. so Zero VED
Comment
Search this Guide:
(G) Help With enginebay, 1,3 Multijet 75hp 2009 QuboSE Qubo 10 14-08-2020 22:59
(T) DIY Servicing Panda Theleman Panda 77 28-06-2019 15:53
(T) connector in enginebay ? Fiatrick Bravo / Brava 4 11-03-2015 18:12
(T) Fiat 500 Twinair - Servicing help! ntanswell 500 30 29-08-2014 21:28
