Ottocentocinquanta
Hello, I have a 1971 850 Sport Spider that I am bringing back to life.
Has been sitting since the 90's...
Got the engine to spin, it was slightly seized initially. Also freed up the ignition switch, that was seized too. Now, when I turn the key, I hear a "bong" sound like a relay engaging. And then when I turn the ignition to "start" the engine turns over like it should.
However, once you let the ignition go back to "run" the starter is still turning the engine over. Turn the ignition all the way "off" and it is still turning the engine!
Currently the only way to stop the starter is to remove the battery terminal to cut the power.
I have bench tested the starter and it seems to work as it should.
I am wondering if the connections at the ignition switch could be hooked up wrong?
I can post a picture of a drawing I made of the ignition wires and their location.
Any insight is appreciated
