Old 30-06-2021   #1
Airbag light
Hi all and thanks for letting me join 👍
Sorry to join and post for help straight away but needs must.We own a fiat ducato based Motorhome.We have read a lot about the airbag ECU since our light came on 😞 Long story short we sent ECU to Crash data who told us it was un reapairable so we needed a new one.After waiting 7 weeks ( on back order) we got a new one and sent it off to CD for coding, fitted it and still got airbag light on 😳 CD said they needed a code so paid for data code reading and it comes up with U1700 NBC, which means nothing to CD 😲 Can anyone offer advice please ? Been onto main dealers and they say CD cannot re code off vehicle which we know is not right because we know of over 30 people who have had it done by CD ....any help please 👍
Terry
Jerry890 is offline Reply With Quote Quote
Old 30-06-2021   #2
Re: Airbag light
Have you checked the connectors under the seats?
If they work loose, the can show an airbag error
RichardH13 is offline Reply With Quote Quote
Old 30-06-2021   #3
varesecrazy has donated!
Re: Airbag light
Hi
Is that the full code?
Either way its a communication problem
https://www.fiatforum.com/grande-pun...7=#post4357412
Old 01-07-2021   #4
Re: Airbag light
When fitting a new SRS unit, it has to be "coded" to the vehicle by running a proxi-alignment. This allows the van to discover the new module, re-write the master configuration file in the BCM and distribute it to the slave nodes on the vehicle.
Crash-Data use equipment to clone a new or replacement SRS ECU by copying the information from the old unit that was fitted to your van into the new unit, so that when the new unit is fitted, as far as the vehicle is concerned it is the same unit that was removed, and no "coding" is necessary.
Fiat dealers don't have the specialist equipment necessary to do that. If a unit is faulty they replace it and program it into the vehicle in line with Fiat instructions.
There are two U1700 fault codes that I can see relative to the SRS system. The fault codes should have an additional two digits after those first five characters, so either the diagnostic equipment used to retrieve the codes isn't fully compatible or you haven't been given the full code.
U1700-86 means implausible data received from BCM
U1700-87 means no communication with BCM
First option would be to clear the fault and see if it returns, as it may be related to the initial SRS ECU failure. Otherwise if you know someone with, or have access to MultiEcuScan or AlfaOBD, try a proxi-alignment with the new SRS ECU fitted.
RS3100 is offline Reply With Quote Quote
Old 02-07-2021   #5
Re: Airbag light
@RS3100 are there any codes that indicate the ecu is US (knackrd) or is it just a question of clear it and see if it works now? Are there ways of saving data and restoring it, using MES or alfaobd
Are there other useful things we could be doing with this software to relieve possible agro in the future.
theoneandonly is offline Reply With Quote Quote
(T) Airbag light on suspect airbag ecu wooldra Barchetta 1 16-02-2018 20:07
(T) fan heater not working and now airbag light on and passenger airbag light constant fl mikehopper Punto (Mk2/2b) 30 04-10-2015 19:52
(T) Airbag light on passenger airbag problem - Fiat Idea GRBASF Idea 6 06-04-2015 22:03
(T) Airbag light will not go off! No communication with airbag control unit? Monky 500 15 07-09-2014 14:58
(T) Airbag light on...yeah another airbag post lol xxchrissy88xx Punto (Mk2/2b) 18 13-05-2014 08:05
