Hi all, new to this site and wonder if all you good people can help.. we have a Fiat 500 61 plate dual logic lounge, recently we have several problems:
1. Mileometer is flashing
2. Airbag lights on
3. Stop Start light on
Everything was fine and then one day all issues as listed above. Have tried the general recommendations and had a new battery fitted ( the old one had been on from new) Our local garage had a computer that tested the electrics, however after finding the issue could not fix as apparently only a Fiat computer can fix and reset.
The seats had been moved back and forth and this is when the issue seemed to start, garage checked connections under both seats and all seemed in tact and ok.
I now suppose I have to go to a Fiat garage, which I don’t particularly trust, (all local ones are Stoneacre ?)
My local garage seems to think they can fix relatively simply with their own Fiat diagnostics, but I am worried they will blind me with science and charge a fortune!
Any help or advice would be much appreciated.
Thank you in advance ?
2. Airbag lights on
