Johnny1372008
- Aug 18, 2020
- 9
- 2
2014 Doblo 1.6 lwb van heater fan stopped working checked fuse and is okay can’t find thermal fuse mentioned on another thread anybody experienced this
Thanks J.O.
Thanks J.O.
On several VWs i owned regularly the resistors were shot. Replacing them with more heat resistant types usually solved the problem.Favourite filure is the wiring at the plug for resistor .. give it a wiggle.. see if you get any power
I removed the bladed fuse for rear window heater as it’s a van and put it in holder next to it for another heater and fan started working then stopped then would work intermittently put fuse back and blower worked then stopped and I have ckecked wiring to resistor and terminals look new so I’m thinking maybe earth somewhere?
Have you used a meter to see what is happening at the motor terminals..
A bad connection..or earth..
Will be obvious if a wriggles skips voltage from 3..or4 to 12
