Aaarghh FIAT
- Mar 29, 2020
- 2
- 1
I will never buy another Fiat again!
Bought this van, 50k miles on it, FSH... Here is what has gone wrong on it in three years:
Due to the unsealed joint in the two piece plastic cover between the bonnet and windscreen, water leaked in and corroded two of the injectors so badly they failed. My honest Fiat dealer stated the fuel pump, DPF and all injectors had failed....really, at the same time! They also won't attempt to remove the injectors because the heads always breaks, so £500 for a head on top.... Removed vehicle to an independent (friend of a friend) he said they will not work on Fiat as a rule as they are like boomerangs.... once touched keep coming back!
I was present at his request, to witness all but one head bolts sheer, again due to corrosion......... £5000, later van back on the road..........£3700 cheaper than the Fiat dealer though... Will run out of space so will add further issues on separate threads......
