Old 19-01-2018   #1
Twinair cold start problem, HELP!
Hi Everyone
I have a love/hate relationship with a little Fiat 500 twinair which I would love more and hate less if it stopped being such a nightmare to start..
It's a late 2011 model with 60k miles which i've had for 2 years now, i do approximately 18-20k miles a year, mostly motorway. I must say, it's been a pleasure to drive for most of my ownership, however, in November 2017 I started to have issues when trying to start the car on a cold morning, it sounded like it was firing on one cylinder and took ages turning the key to get it fired up, after running for a few minutes the car behaves normally..
I took it down to a mechanic friend who put his diagnostics on it and it came up with a cylinder 2 miss fire, having done a little research this pointed to a possible faulty lambda switch so £150 later an NGK lambda switch was fitted and it seemed to behave ok for a few week or so, all was good.. Then the dreaded startup problem came back.
Question is, has anyone experienced this problem before? does anyone know what it might be?
Any help would be much appreciated.
Thanks, Rob
Forgot to say, it's only ever been serviced by Fiat Ancaster, It did feel a little sluggish after the last service but this may just be me expecting too much from my little Fiat.
Robt1970 is offline Reply With Quote Quote
Old 19-01-2018   #2
Moderator
Re: Twinair cold start problem, HELP!
Hello and wecome to the forum.
I wouldn't expect a faulty lambda sensor to affect startup when cold, as the fuel control system should be running open loop at this point; it might affect hot start capability.
It's not easy to diagnose a fault sitting in front of a keyboard, but this sounds to me like it's an ignition problem. My first suspect would be the spark plugs, closely followed by the coil packs.
Coil packs are a known issue with earlier TA's and there have been both recalls and warranty replacements on some cars from that period; it could be worth checking if there's anything outstanding on yours.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 19-01-2018   #3
Moderator
Quote Originally Posted by Robt1970 View Post
£150 for a TA lambda sensor seems a little excessive; it's only a few minutes work and the part can be bought for half that.
Old 19-01-2018   #4
Thank you for replying to my post, the spark plugs were replaced on the last service (sept 2017) I will get these checked just in case. I'm not sure about the coil packs, they certainly weren't on the invoice for the last service. The thing is, when you let it idle for a minute or two it jumps around like crazy and sounds rough, certainly not drivable. If you turn the engine off then on again, its absolutely fine and runs as normal. I had a porsche 997 which had a number of split coil packs and this had a similar rough idle but it was constant, you couldn't get it to run smooth by restarting car like i can with my Fiat 500.
It certainly does look like an electrical fault, whether its ignition or ECU, Im not sure, but it would be nice to hear if anyone else has experienced the same fault with a successful fix..
As for changing over the Lambda, it did look like a bit of a job, took about 1 hour or so, engine cover, battery and tray out, the switch holder was under the battery tray so not possible to unplug easily without stripping a bit out, I guess being in London, prices are a little higher but i needed a quick fix so would have paid regardless..
Old 19-01-2018   #5
Too many hobbies
Bookish's Avatar
Bookish has donated!
I just had my twinair actuator replaced, lets hope its not that!!
Read my thread further down "serviced my twinair plus yesterday"
If it turns out to be coil packs I have a couple with about 30k on. I replaced mine when I didnt need to. You can have them for the cost of postage to try them out if you like? Save a few quid.
my farts hospitalize small children
Bookish is offline Reply With Quote Quote
Old 19-01-2018   #6
Too many hobbies
Bookish's Avatar
Ps Fiat oil changes aren't frequent enough on the twinair engine.
Old 19-01-2018   #7
Too many hobbies
Bookish's Avatar
Forgot to mention the clutch linkage that can fracture (mine did) and caused the same symptoms but I don't imagine that would throw up a mis fire reading?
Old 19-01-2018   #8
Full Circle
Mercky has donated!
Ireland
I wonder did they use the correct oil in the last service? If the wrong oil is used they can definitely be rough at idle when cold. Itís a specific oil and not at all unusual for the wrong spec to be used
Likes Bookish liked this post
Mercky is offline Reply With Quote Quote
Old 20-01-2018   #9
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
Assuming the oil is correct spec and level(remember the oil level needs to be checked immediately after turning the engine off), then I suspect it's the UniAir unit. Could be as simple as a blocked UniAir filter as these are never cleaned by anyone
2012 Fiat 500 Twinair+ 2016 Renault Trafic dCi140 LWB 2009 Proton Arena 2005 Jeep Wrangler 2005 Toyota Prius 1989 Nissan Skyline 1949 Ford F1 255 V8
UFI is offline Reply With Quote Quote
Old 20-01-2018   #10
Too many hobbies
Bookish's Avatar
Quote Originally Posted by UFI View Post
Thats where Im going wrong, I normally wait until the oil drains to the sump before checking the level
Old 20-01-2018   #11
Too many hobbies
Bookish's Avatar
Surely as long as I put the correct amount of oil in at oil change and it shows on the dipstick then that is the level I look for when topping up after the oil drains to the sump?
Old 20-01-2018   #12
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
If the car is parked too long oil will continue draining from the UniAir unit.
Quote Quote:
The best time to check the engine oil level is about five minutes after a fully warmed engine is shut off. Do not check oil level before starting the engine after it has sat overnight. Checking engine oil level when the engine is cold will give you an incorrect reading.
Old 20-01-2018   #13
UFI, there has been some recent discussion on the 500X forum about the Multiair filter blocking in the 1.4 MA engine. In that case, it is fairly accessible, and not an expensive part. Do you have any details of buying/fitting the equivalent part in the TA? It could well be the problem, and could be a simple fix.
TrevC is offline Reply With Quote Quote
Old 20-01-2018   #14
Full Circle
Mercky has donated!
Ireland
Quote Originally Posted by TrevC View Post
I donít think you replace the filter, you just remove,clean and replace. Thereís a thread in the Panda section
Old 20-01-2018   #15
Just had the Plugs and coil packs checked, all seem to be in good order, thanks for the offer Bookish..
I tried to start it today at 3 degrees and it didnt like it at all, went into limp mode with the engine light on, after letting it run for a few minutes I turned it off then tried after 10 seconds or so and it was perfect, smooth idle with full power..
BOOKISH, Did yours have an actuator problem with the same symptoms as mine ?
(T) 900cc Twinair rough start from cold Putput100 500 10 10-08-2017 12:00
(G) Fiat Punto TwinAir cold start issues kirby11 Punto (2012+) 0 11-11-2015 13:01
(T) Cold start problem georgeago Coupe 19 15-09-2015 14:55
cold start problem thoren Lets Talk FIAT 1 29-08-2013 02:02
