Fiat 500 twinair from South africa
Jacovolmer
South Africa
Hi All, thanks for allowing me on. I have a 2016 fiat 500 twinair 900t. Need some advice. Thanks again Jaco
Thanks Panda Nut! I created one asking the flywheel torque specs for a twinair with dual mass flywheel. I appreciate the welcome. Keep well
I had a quick look myself and a manual twin air says 140 -160 Nm plus 35 degrees. But you should check to make sure it the right one for your version.
Very interresting. Thanks. I found after taking the trans out, its a 2016 model, but it had a single mass flywheel. According to the vin and age it was supposed to have a DMF. I suspect someone was already in there and changed it. Hence the mechanic thought he could keep the new flywheel and pocket the cash. Thanks
