Hi All,
I’ve spent a while reading past forum posts , the steering wheel removal guide and downloaded the eLearning stuff but I still need some guidance re removing the steering wheel on my 2002 Ducato 2.8 – I think it may be referred to as a 230(? – something I picked up off the internet).
The steering wheel type is as pictured. I’m assuming that to remove it I will have to puncture the base of the steering wheel at the point where the holes are marked?
My issues are
1. There are four hole points marked so should I pick the ones widest apart?
2. How much pressure is actually needed – I tried one hole and other than piecing the soft outer steering wheel covering I could not feel any give which given that a spring is involved I’d have expected to feel some movement. Just trying to avoid causing more damage than I’m repairing (faulty steering column switch).
Many thanks
My issues are
Many thanks
