the 1.6 is 1300kg towing capacity, if you look on the plate in the engine bay it gives the gvw, front and rear axle capacity, and the towing capacity
the nose weight is to do with the trailer not the towing vehicle, if you mean the max nose weight that the towbar can accept then I would check with the specifications of the tow bar,
