seicentoowner
- Nov 2, 2013
- 28
- 7
I have an issue with my 04 PANDA 1.2. I couldn't get 5th with out the box grinding, it then got worse and i couldn't get first or reverse as well. thought it was a clutch cable issue until i realised it has a hydraulic clutch. Strangely the problem seemed to have fixed it's self when i changed the break pads on the front. this fixed it for a few weeks until yesterday when it started again. today i took the front passenger side wheel off. took the pin out of the break caliper and pushed the piston back that is in the caliper (to do this you must take the cap off the break fluid reservoir) then put it all back together and it seems to have fixed it again, don't know for how long. if anyone could help with a longer term solution or explain why this seems to fix it temporarily I'd then be in a better position to spend some of my limited income on replacement parts to make it a permanent fix. TIA
