Porttackflyer
Hi
I've just picked up a 2010 black panda 100hp.
Forum has been very useful in reading up on the car.
Really pleased with the car. I used to have a cooper s and there are some good similarities (although the panda is 70% cheaper!).
Just planning what needs to be done:
Wheel alignment (record of uneven front tyre wear, sounds a common issue)
Car has done 48k, should I get cambelt and water pump done?
Overdue a service, should I use a fiat specialist ideally (any recommendations in South Devon/plymouth area?) or will my local Indy be fine?
Air filter - anything that can be done here for improved sound and a few more hp?? (Low cost)
Drivers side washer jet is spraying mainly over the top of the windscreen, how can I fix this?
Thanks for any advice
Adam
Adam
