Grande Punto cd player
azbo1991
Hay guys I have a fiat grande punto 1.9 and I took out the cd player to plug in my new aux cable after putgig it all back in it says no source found when press cd and when.I put on the radio I can't get a signal at all the channel name ie radio one comes up on the screen but just get fuzzing can anyone pleas tell me what's wrong with it
Many thanks
Double check the aerial feed, big attachment on the right hand side on the back of the unit as you pull it out :)
Disconnect the negative battery terminal and leave it off for an hour or two, this will reset the ecu. You will have to reset the clock etc but that should work. Do you have your radio code for the unit? Might need it, I never but think it varies from model to model.
