Stephen505
- Dec 13, 2013
- 74
- 20
Hi folks,
I just want to share my current experience with my interittent stiff power steering issue which is very common on most Fiat Punto Mk2 cars.
I started to have the problem by now 3 years ago and I have been studying the symptoms for long. I have also came to a temporary, or perhaps long-term fix, if of course my fault is the same as the odd common fault.
So every now and then, the power steering warning light came on and the steering hard stiff almost unmanagable for parking of quick turns. However, when you turn the car off and again it goes for a while. I found out that I could extend the 'while' for days, weeks and sometimes a month or two if you change the level position (how up and down) of steering column. I also figured out (use at your own risk) that if you raise the steering column up and down a bit roughly/hard so that you knock 'gently' some internal parts, the next time ihe problem occur will take longer.
My mechanic told me that this would last for a maximum of 6months until the expensive faulty part needs replacement, but now 3 years have passed and the problem has not yet passed the threshold level to cash out the money for a replacement, since it occurs an average of once every week. A little dash on the steering and it is fixed.
I even started to believe that there is some loose contact or wiring problem, but this can be verified only when the steering column is open
Any comment similar experiences are welcomed
Happy New Year
Happy New Year
