two screws/fasteners behind kick panel
two below ashtray
lower console out
4 screws /fasteners holding heater section in undo screws so heater section can move slightly
undo 2 screws/fasteners holding window switches in ,remove single or both rear loom clips put unit on a work bench ,remove mini philips type fasteners and check bulbs
or borrow a replacement to see if it is a bulb issue
