Old 3 Weeks Ago   #1
Temp gauge going up to max and not starting
Temp gauge went up to max and engine cut out not overheated got towed home then fault went away and engine running normally . Has happened again today ignition on and temp gauge shoots up red warning light comes on and engine cuts out Any ideas
Ronste is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Trader Rating: 1
portland_bill has donated!
Re: Temp gauge going up to max and not starting
First thought would be that the temp sensor is failing, and the engine has a safety cutout to prevent overheating causing damage.
High temp reading with engine cold points to sensor or wiring.
Find the temp sensor. There may be moe than one.
Disconnect it and see if the reading drops to zero. If it does, try to start the engine. Don't run it for too long, as it will be running richer for a cold start.
Follow the wiring to ensure not chafed or burnt against anything.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is online now Reply With Quote Quote
Old 3 Weeks Ago   #3
Quote Originally Posted by Ronste View Post
What version of Ducato does this cry for help, relate to? Please see "sticky" at top of Ducato section.
Communicator is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
Fantastic result from Portland Bill you got it right disconnected temp sensor and all ok new one ordered
Thank you again only joined site in middle of a sleepless night and now problem solved
Likes Ocwobio liked this post
Old 2 Weeks Ago   #5
Australia
I recently had a similar problem.
Mine was a faulty thermostat which I replaced now....after much swearing! lol
Depending on the age of your vehicle, I would consider replacing the thermostat also
if it is very old.
I am now looking into replacing the said Coolant Temperature Sensor?
Trying to determine if that needs replacing also...
Peter IceVovo
2006 Fiat Ducato Maxi 2.8 JTD Intercooled TurboDiesel with Auto Transmission.
x244 Body
IceVovo is offline Reply With Quote Quote
Punto (Mk2/2b) punto mk2 1.2 16v temp gauge just above 1/4 (new termostat and temp sensor) Shannon87 Newbie Central 18 02-03-2015 19:13
(T) Temp gauge max - chemical smell? dannyhill94 Punto (Mk2/2b) 3 28-02-2015 10:16
(G) Punto Trip computer reset, Issue with temp gauge/petrol gauge Hottwire Punto (Mk2/2b) 2 22-12-2011 22:42
(T) fiat brava 80 sx speedometer temp gauge petrol gauge not working but lights are on sunshine69 Bravo / Brava 3 23-08-2009 08:50
Injector light on, Temp Gauge at max airbud1970 FIAT Boo Archives 4 14-09-2004 17:59
