Urgent - Ongoing issue - Need some help P1171 code
soc
Member
South Wales
My partners Fiat 500C 1.4 16v 2009 (35k miles) has had this engine light fault for years and no one has managed to find the issue. I have taken it to a number of Fiat specialists who say, its an intermittent fault and the engine is running fine (fuel trims and oxygen sensors etc are reading within the parameters). MAP, spark plugs, coil packs, pre cat oxygen sensor, fuel pressure checked etc have been replaced.
I would appreciate someone with the tech know how to take a look at the freeze frame readings below at the time the fault was triggered and suggest where the fault may be. I suspect a wiring or short issue.
Thanking you in advance
Soc
