im Axle Specialists
Old 24-03-2010   #1
MiniMonster has donated!
Question Why are Brake Pedal's higher than Accelerator Pedal's?
Today i realised that i didn't know the answer to this question which i thought of years ago.....
Why is the Brake Pedal higher than the Accelerator Pedal???
This don't make sense to me atm because lets pretend that your driving along and suddenly Bambi's Mother jumps out in the middle of the road.
NO ONE wants Bambi's mother to die, surely. So now you either stop in time and save her... or you destroy Bambi's whole world
If the Brake pedal was the same height or lower than the Accelerator Pedal then there would be more time saved to Brake, compared to having to lift your foot further to reach it.
So can someone please explain why Bambi's Mother has to die?
MiniMonster is offline Reply With Quote Quote
Old 24-03-2010   #2
Ulpian
Ulpian has donated!
Re: Why are Brake Pedal's higher than Accelerator Pedal's?
Well, to misquote Chandler Bing:
'Bambi's mother didn't die, the artist just stopped drawing'.
The old oleopneumatic Citroens had a button on the floor instead of a brake pedal, and when you hit that the cars just STOPPED!
In fact, I believe the old DS was the shortest braking car until very recently - indeed - certainly it still held the record when ABS was introduced. But it had excellent inboard disc brakes anyway.
Other than that, I don't know
Ulpian is offline Reply With Quote Quote
Old 24-03-2010   #3
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
My guess is that it's just convention. The brake pedal has always been in that position, so keep it there.
The height of the pedal probably goes back to early cars with mechanicaly operated brakes. It needed a lot of travel to maintain brake pressure through brake rods and fulcrum trees to keep the shoes on the drums.
I occasionaly borrowed a Citroen DS years ago and as Ulpian says above, hit the button and the car just stopped. However, it was difficult to get used to and equaly difficult to re-adjust to to my normal car again. Possibly why the idea never caught on?
There was a similar situation with the QWERTY keyboard, which contrary to popular opinion, was actualy designed to slow down typing. Early days of mechanical typewriters, if you typed too fast, the levers and type hammers would get jammed.
The advent of the PC would have been an ideal time to change the layout to make typing faster, but everyone said no, just leave it how we're used to it being.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 24-03-2010   #4
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Maybe because the accelerator always has your foot on it, and if it were too high the angle of your ankle would provoke ergonomic pain, the clutch pedal has further to travel so cannot be lowered, so it makes conventional sense to have the brake & clutch pedals at a similar height with the accelerator slightly lower for ease of use & comfort.
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 24-03-2010   #5
BRUM!!
maddogmorg's Avatar
maddogmorg has donated!
Bolivia
possibly to stop the brake pedal being pressed at the same time the accelerator is pressed and vice versa.
guess it helps increase distance between pedals without needing extra physical space? for example a pug 106 would be impossible rather than extremely difficult to drive, if the pedals were all level.
________
(________)
maddogmorg is offline Reply With Quote Quote
Old 24-03-2010   #6
Moderator
I can think of three possible reasons. The first is that if the brake was at the same height, or lower than the accelerator, if you tried to carry our an emergency stop, you could hit the gas rather than the brake. As it is, if your foot is a little off to the right when you tried to stop, the brake pedal would already be partly depressed as you caught the gas, so you'd still have some braking effort.
The second is that in earlier times, double de-clutching was common place with non-synchromesh gearboxes, as was the heel and toe gearchange. It would be impossible to carry out h&t if the brake pedal was lower.
In the days before servo assisted brakes the pedal used to go down a long way and sometimes had to be released and re-applied; pumping. Even now, if your servo packed up, a very short pedal travel would limit your ability to stop.
The Beard is offline Reply With Quote Quote
Old 24-03-2010   #7
Moderator
Quote Originally Posted by maddogmorg View Post
Quote Originally Posted by The Beard View Post
Oi! Stop writing what I'm thinking - git.
Old 24-03-2010   #8
Does anyone actually know the reason?
(Oh, its so you don't get confused between the brake and accelerator. No, really, it is)
scoop987 is offline Reply With Quote Quote
Old 26-03-2010   #9
It's all very interesting
Old 26-03-2010   #10
J333EVO has donated!
Post Re: Why are Brake Pedal's higher than Accelerator Pedal's?
The brake pedal is higher than the accelerator pedal so that when you can heel & toe.
When you brake the pedal is pressed so it becomes level with accelerator pedal so you can then blip the acc pedal and rev match your downshifts.
This is blooming obvious for anyone who can drive.
One criticism of the 500 (including Abarth) is pedals are same height making heel & toeing near impossible, lots of drivers have raised comments as such in the Trofeo series and find it very disappointing a race car still has same pedal positions as the road cars. And a few of the proper publications like EVO mag have also said you needed a double jointed ankle to heel & toe.
This is why many driver oriented cars also have a small lug sticking out from the acc pedal to make it easier to heel & toe, though there is a minimum MOT requirement of having 50mm between pedals.
Cinquecento Abarth 1.4 16V
Lancia integrale EVO1
BMW M140i
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 26-03-2010   #11
So it's really all down to the Heel & Toe?
I personally can't get get to grips with the Heel & Toe... I can double de-clutch but it's probably my driving stance that stops me being able to Heel & Toe, my legs are long
I totally love Sega Rally Championship, i got it on the Sega Saturn
Old 26-03-2010   #12
Yes it's because of heel & toe.
The SEGA Rally is because I have an integrale EVO and used to have a Celica GT4 ST205 as well at the same time living the SEGA Rally dream.
BMW M140i
VW MK5 Golf R32
Old 26-03-2010   #13
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Well I never... all cars are produced to a standard so that the odd 10% of drivers who need / want to heel & toe can do so....
I'll accept it may be convention from a time heel & toe was necessary though...
I know the racers like to do it but I'll bet 90% of road drivers dont, further I'll bet 90% of that 90% dont know how to heel & toe or why they may need to...
Old 26-03-2010   #14
Trader Rating: 3
ycming has donated!
Hmm i think is a MOT failure if the gas pedal is higher than the brake pedal?
I agree with that when emergency braking you need the brake pedal higher than the gas pedal
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 26-03-2010   #15
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Ffoxy View Post
I doubt that even 1% of car drivers heel & toe and I think it very unlikely that the worlds car manufacturers have designed a system that 99% of their customers don't use/want/need.
petrol higher than diesel... sammiboo Leisure Lounge 28 27-06-2009 15:03
(G) Higher output alternator? cheeqic_nto Cinquecento / Seicento 16 21-04-2007 02:32
(T) higher boost + higher compression ratio arc Cinquecento / Seicento 2 07-04-2006 18:57
using higher amp batteries dave Lets Talk FIAT 4 02-12-2005 15:33
(G) Higher mileages... 20VTDreamer Coupe 5 06-09-2005 19:46
