Part of the current diesel MOT is a single rev to the limiter.
For a fast pass yes - more are needed when taking an average smoke reading on an mot.
Passed 3 MoTs with my JTD and as already said the counter is still at zero.As said by HC diesel smoke test would need to go full throttle so would that cause over rev log entry ?
As already pointed out by ducasi that simply means the engine has been over-revved so many times that the counter has lost track. It would translate to extreme abuse
What would be significant is if they never reject (or at least warn about) engines in the range of say 50-100 or 100-200 times etc. This would be statistically significant and might indicate a software glitch exists :chin:
They don't do that now, or shouldn't need to. Single rev to limiter.
er...
It's not hard to hit it, it's not hard to go over it. I've dropped into 3rd once instead of 5th coming down from 6th and almost over-reved but as the clutch started to bite I noticed quick enough and engaged the cluch back in fast enough to prevent an over-rev.
That might be true of the classic view of a diesel but if you'd ever driven a JTD then you wouldn't make that comment.I should of been clearer, what I mean is a diesel generally revs up slower than a petrol, you've got much less of a chance therefore of hitting the limter.
I can assure you in the lower gears, when remapped, the tacho needle is like a blur :devil:
I think the view is that it's not even possible to register an 'over rev' count except in the case of severe engine braking :chin:Just interested as to WTF you putting too many revs on engine has to do with the gearbag going pop.
Must admit to being a little puzzled by your comment mentioning 6500rpm on a diesel. Most, if not all the "small" diesels I've ever driven have produced maximum power at just before 4000 revs. 6500 must represent an over-rev of about 60%. Is any standard diesel capable of those sort of speeds?This was the idea when I started the thread.
In the particular case I have started digging a bit deeper. It is claimed that the car had 3 over revs of 1800 milliseconds at 6500rpm on a Diesel. Also it emerged (much later although they knew it) that the rpm sensor had a fault. Still warranty warranty is refused.
Next step is hitting hard. But would help to get more cases together and it will go to the relevant authorities.
It would be interesting to check out a brand new car and see what is logged and if it red 255 that would cancel fiats claim and put it back as a design issue!?! [retired ex warranty engineer]The number was 255, and it's not that suspicious as that's the highest number a computer can store in an 8-bit counter. Once the count reaches 255 it must stop counting.
After speaking to some of the lads at Stanford Hall it became clear that what a number of people suspected actually seems to be happening.
Quite a few claims are refused because supposedly the engine has been over-revved so often.
As this is a very serious topic: Please refrain from spamming.
If a pattern can be established steps will be taken to bring this to the public attention. This can only be done when we have all the facts and not just speculation and hear-say.
Currently I help Red Dot to overturn the claim refusal on grounds I would call at least dodgy if not fraudulent.
